Fightman's Build Thread
For those of you who don't know, I was having Hard Starting issues with the 4Runner for a few weeks now. Seemed as though, it would start ok in the morning when cold, and again if I would turn it off but then start it right away. However, if I let it sit for an hour, and then tried to start it again, it would take 3 turns of the key to get going again. After troubleshooting, exchanging some E-mails with another forum member, I figured it might be the Refurbished Fuel Injectors I purchased off E-bay to solve my CEL and rough running condition.
I contacted the seller, who advised that he had a bad batch of injectors that had come out, and were basically causing vehicles to flood, due to a over flow of fuel coming from the injectors. He also advised that some of the O'rings were faulty, and causing fuel to leak as well, and advised that if I could find the faulty injectors, he'd replace them at no extra cost. However, not having too much faith in his product at this point, I decided to try and just swap 5 of the 6 out using my old injectors, and see what happens.
I wanted to tackle it a couple of weeks ago, but decided that this time, if I was taking apart the intake plenum, I was gonna change out my Valve Cover gaskets too. So I ordered some from Air Cabinman and waited for them to arrive in the mail. After about a week or so, I got them in, and decided to tackle the job today!
So, my buddy and I decided to try and fix my hard start issue 1 more time! But this time, we took a drive to my dad's place, and used his HEATED 2 BAY GARAGE!
We ended up taking the intake plenum off again, and swapped back in the 5 old injectors, leaving only 1 Refurbed injector in the Cylinder 1 spot. After driving it home, leaving it parked for an hour, and then going back out to restart it..... IT STARTED UP WITH NO PROBLEMS!!!!
Here's some pics from today:
DSCF6419.jpg~original
The old valve cover gaskets were brittle!
DSCF6418.jpg~original
DSCF6417.jpg~original
Ah yes....the ever so common brittle electrical conduit:
DSCF6415.jpg~original
Torquing down the valve covers
DSCF6414.jpg~original
Not too shabby looking in there:
DSCF6410.jpg~original
DSCF6409.jpg~original
I'm gonna test it thoroughly over the next few days, but looks like this was the fix! Lesson learned....don't buy expensive components off E-bay....you never know what you're gonna get!
P.S: Interested in having a good laugh??? My buddy recently did a brake job for my cousin on his Chevy Optra....only to find that this was all that was left of his Rotors:
DSCF6411.jpg~original
THE ENTIRE INNER FACING OF THE ROTOR WAS ALMOST COMPLETELY WORN DOWN! HE HE HE!
And you thought I procrastinated on maintenance issues..... ;)
Glad to hear you finally got the hard starting problem nailed down. Now you can go back to just enjoying the truck.
What's the next mod going to be? I know you're out of work for the moment, but I'm sure that sooner or later you wont be able to take it anymore and you'll think of a creative, yet frugal project.
Thanks for the comments guys! I really happy so far...just hoping that it wasn't just a fluke! I'm going to drive it tomorrow, see if it acts up, and go from there.
After having issues with her since December....it's a little hard to believe that it's finally running well.... he he he!
The valve cover gaskets were actually pretty easy! Once the intake plenum was off, it was just a matter of unbolting them, removing the gaskets, and putting the new stuff in. As long as you have the right tools, it's a breeze.
Basic ratchets, universal joint, 10mm and 12mm sockets did most of the work....with the use of a hammer, and large socket to press the spark plug tube seals, and maybe a small pry bar to remove the old ones.... the job went fairly smoothly. We also used a Torque Wrench that measured Inch/lbs, to torque the valve covers to 52"/lbs, but that was already purchased by the wife as a Christmas gift.
As for my next mod, not quite sure. I may paint my SR5 Spoiler, not sure. Also thinking of a couple of other small mods....so stay tuned if you're interested!
Thanks again for the comments!
A buddy of mine convinced me to give the seller another chance, so now I'm waiting for 6 more injectors to arrive in the mail, so that I can put them in. I'm really hoping this works, as I really don't want to take it all apart again after this last attempt!
Fightman,
I am pulling for ya for the new ones to work.
I had an Ebay seller drag their heels in sending me some items last month and due to their own admission of ****iness, I was sent more items that I had originally won. So I will try and forward on the good karma to ya.
I'd have to look at the injector bodies, and see if I can see any markings to confirm this. I kinda took his word for it.....
To tell you the truth, I've always been very reluctant about buying parts on E-bay. I've seen so many of you guys do it with such success, and thought I'd give it a shot.... lol! THis guys was a Power Seller, with only good reviews. His communication was good, and all seemed to be on the up and up.
I'm definitely not going to be buying critical parts off E-bay anymore....to much BULL$h!t involved if things go wrong with the parts....
I really hope so man....but looking at my pick...I noticed he left out one 0-Ring on the very first injector on the left. Lucky for me, I bought a few 0-ring kits from the part store. That being said, I got them here, covered in fuel, and a missing O-Ring..... I'm not holding my breath..... :roadkill:
For the love of CHRIST!
Well, one long day later, and my truck is not running on all Cylinders..... :(
I don't know what's going on yet....might be the New injectors, I may have plugged them up with vaseline (trying to lube them for the install), or could be vacuum issues! FML!
Anyway, I tore everything apart again, and replaced all the Fuel Injectors with what the Seller sent me. Then I decided, since I had it all taken apart again, why not paint the intake manifold??? :)
I saw a few of you guys running the TRD Superchargers on the 3.4L and decided I liked the color scheme that they had....so:
DSCF6459-Copy.jpg~original
DSCF6457-Copy.jpg~original
And a quick before and after:
DSCF6454-Copy.jpg~original
DSCF6461.jpg~original
I know my engine bay is still dirty....I'll get to cleaning it up in the next few weeks!
But first, I've got to get this thing running right! LOL! My buddy is coming over in about an hour, so we're going to try to trouble shout, and see what's wrong.
I'll keep you guys posted.....
DJNutshell
