Finally Tundra 13WL brake upgrade...56k beware
Have you had a chance to install the callahan kit? Any issues?
I've been running a kit from Callahan for nearly 3 years now with no issues. I don't particularly care for the drilled/slotted rotors(no actual issues, just not a fan) and at the time I could only get the calipers in red, not black. Functionally, they've been flawless.
No yet I’ll do it this wknd. I’ll keep you post it. I wanted to add some stickers to my calipers too. Take a look
Wait...powder coated rotors? They can't be serious.
I was just about to say... wat
i mean i guess its good for anywhere that doesnt get pad contact but does it just wear off in the first little bit or would it screw with your pads?
I did the same set up about a month ago...love it!! The powder coat wears off on the break in...no issues at all.
Sent from my SM-G955U using Tapatalk
I installed them today went pretty good no issues .
If you have these rims they will work with this upgrade not need to do anything special
I'm unable to find this kit on Amazon. Curious to how it's performing and if you can link me to them? Thanks!
Currently listed on Amazon under that brand. Similar. Pretty good price.
CCK11988 FRONT Powder Coated Red [2] Calipers + [2] Rotors + Quiet Low Dust [4] Ceramic Pads Performance Kit
$337.10$337.10
CCK02111 FRONT Original [2] Calipers + [2] OE Rotors + Low Dust [4] Ceramic Pads Kit
$179.39$179.39
$337.10$337.10
$179.39$179.39
Diesel, Thanks for taking the time to dig this up for me...much gratitude. Either of these will work on my 01?
Yes, tundra (2005 is the year I use) brakes fit the 3rd gen 4runners.
Fitment under the rims is the concern. Do a search, there are lots of threads on it talking about most any rim model.
It’s also in the stickies mod thread.
For me, the only 16”+ rims I’ve found to not fit were the early 3rd gen 16” split 3 rims (6 spokes paired up in 3 sets of 2).
Hoping I can get some help here.
I ordered 2005 Tundra rotors and pads from Amazon and the rotors are huge. They are 12.5"
231mm rotors are just over 9"
Here's what I ordered:
Amazon.com: Power Stop K2324-36 Z36 Truck & Tow Front Brake Kit: Automotive
Every where I search for Tundra front rotors, every description says 12.5"
I can seem to find the right set anywhere.
I'd like a set of slotted if possible.
Thanks for your help.
The 199mm and 231mm sizing for the Tundra brakes is the caliper size, not the rotor size. You need to upgrade the rotors, pads, and calipers together. You can't just put the Tundra rotors and pads on without upgrading the calipers as well.
ok I understand. I bought my 13WL calipers at NAPA. But aren't the rotors on the 2005 Tundra supposed to be the same diameter as the 4Runner? The ones I got in the link above are much larger. And everywhere I look they are the same size. Can someone post a link where I can buy the right size rotors like Power Stop or some other slotted rotor. Thanks again.
Ok, I figured it out. My 4runner came with 15" wheels from the factory. This means my rotors are actually the smaller ones. 297mm (11.6") vs the 320mm (12.6") rotors many of you already have. The Tundra also used 320mm rotors so they are bigger than the ones I had on my 4runner. This is a good thing as I will benefit from a larger rotor as well by doing this mod. I'll try and install it all tomorrow.
Google tundra rotors, plenty of sellers on ebay, amazon, etc.
Here's a set
Amazon.com: Callahan CDS02019 FRONT 318.77 mm Premium D/S 6 Lug [2] Brake Disc Rotors + [4] Ceramic Brake Pads + Hardware: Automotive
FWIW, that Callahan CCK02111 kit for $172 delivered is super cheap and you can spray the calipers any color you want for another $20 in caliper paint in a weekend
NVBASSJUNKIE
