Fix-A-Flat
Bad_Influence
Sorry if this is a dumb question, but I'm curious if anyone has had any bad experiences from using fix-a-flat tire filler. I love the idea of being able to fill a flat tire up with this can of stuff and having it fill in any air leaks.
My issue that concerns me is that it will add unnecessary weight to the tire and throw the balance off long term? Especially if applied to the same tire more than once. If anybody has any thoughts on this, your opinions would be greatly appreciated! thanks - kurt
Plugs are super cheap and easy to use. A lot of time even being able to be used with the tire/wheel still on the vehicle.
No personal experience but I've always heard the old line of how when the tire with fix-a-flat in it is finally broken down from the rim, the resulting cleanup of that goo is passed on to you.
I've had great results with plug kits on everything from lawn mower and golf cart tires up to 19.5" commercials.
Good luck and hope you won't have to use either any time soon!
- Jeff
If it's an emergency, use it.
If you can use your spare, use your spare. Otherwise, that stuff will damage the TPMS sensor. If you use too much of it, it will throw the balance off until you drive for a little bit. But it's for emergency situations.
Most tire places charge extra to properly repair a tire that has been temporarily fixed with fix a flat. Its messy stuff.
Plugs are also are a temp and easy fix.
Either way, I would take the tire to get properly fixed (plug & patch) after using one of these temp solutions
Not sure on Toyota TPMS, but on my BMW the 'OEM flat tire fixer' which is similar to fix a flat caused me to have to replace my TPMS sensor with a new one.
A plug by itself isn't a perminant fix. The correct way to fix it is a patch plug combo. Unless it's changed from when I managed a firestone while putting myself through college 10 yrs ago.
I have a feeling there's a lot more plugs (running around, unpatched) and that's based on almost 40 years of driving and plugging tires. I was plugging my own tires when you were still crapping green, kid.. But all kidding aside, there's has to be tons of tires sporting plugs only.
Having owned a construction business for quite a few years forced me to get trucks (and men) back on the road as quick as possible...so if I could roll up, plug a tire, fill it with air and be ready to roll, that's how it went. I can't honestly remember a plug failing...
hope you patched tiares betar than you speeled college boy....lol..."permanent"
Wow you are old. That's cool. I guess.
I didn't say it wasn't a fix, it is a cheap on the fly way to fix. Just like fix-a-flat. Hope you don't build things half assed like you fix your tires construction geezer.
Just callin' like I see it kid....:crutch:
Did I mention that the manager of the Firestone up the road was also the manager at the McD's about two weeks earlier??
I guess once you know and understand retail it just stays in your blood...
I knew a guy who was fixing a tire that had this fix-a-flat in the tire and nobody told him, when he got the tire off it exploded because of that stuff and took most the skin from his hand/forearm. This info is from texastriallawyer.com
While trying to fix a flat, many tire workers and others can be blinded, maimed, or even decapitated when the tire explodes. Most of these tires had been previously filled with a can of tire sealant to fix a leak in the tire. The propellant in the tire sealant often times contains the butane & propane. When an ignition source is present a massive explosion is possible.
I carry a can along with plugs, etc. just because you never know but it's there only when I'm too drunk to get the spare or plugs.
My car came with no spare but has this stuff and a small compressor.
Man that escalated quickly... I usually just patch. Unless it is on a ford excursion on a knarly trail, then I just give up and limp it down on the rim because it is the third flat in a day...
Just because you got by on tire plugs doesn't mean they're the right permenant fix. You can throw some thicker oil in a older vehicle (won't work as well in modern vehicles with Variable Valve Timing) with worn rings, but that doesn't "fix" the problem, it delays the inevitable.
The RMA (Rubber Manufacturers Association) has guidelines and an entire website devoted to informing and educating the public, industry, and professionals on proper tire installation, handling, repair, ect. They didn't go through all this trouble to make money off of you; they mainly did it to keep people from putting half a dozen plugs in a worn tire and then endangering others because of it.
I regularly see failed plug patches that leak, I also see many plug patches in side walls on tires you can tell have been driven far too long after the repair. Plugs are a temporary repair as detailed by almost every tire manufacturer, shop, and sometimes even states. While the plug itself is not a bad repair it is prone to improper installation, leaks, damage, and/or endangering others by people using it as a permanent solution to extend the life of tires that should not be used any longer.
I encourage you to read up on the subject, there's plenty of articles explaining why a plug/patch combo is the proper repair for a tire and why there are non-repairable zones on a tire. I'm surprised that you haven't dealt with a lawsuit from an employee who was forced to use a vehicle with a temporary repair, either they were very loyal or very stupid.
RMA: Rubber Manufacturers Association ? The national trade association for tire manufacturers that make tires in the U.S.
Bottom line is that plugs are temporary repairs meant to get you to a safe area and/or repair shop without towing under certain circumstances. They are often abused and improperly done; even when everything is done properly I have seen them leak. It all comes back to "just because you can do it, doesn't mean you should."
As for the OP, Fix-A-Flat works okay for most punctures. But many shops will charge extra for the clean-up and you can gum up the TPMS sensors. It is a royal pain to clean up a tire & rim with Fix-A-Flat in it, but if its all you got; roll with it.
This coming from a guy that lives in a state that requires a 330 page user manual and 17 warning labels on a fishing pole....
Thank you for the 6 paragraph diatribe Dr. Obvious, I'll be sure to gather my legal team in preparation for an inevitable class action lawsuit coming from former employees....lololol.
No where did I say just plugging it was best, permanent, correct, etc. so don't put words in my mouth. I simply stated, over the years, through past experience, it worked....certainly better than slime or fix a flat. Drama, Drama, Drama...
you are better off with a compressor, than a can of fix-a-flat.
if the hole is leaking too quickly for a compressor to be a good solution, then its also too big of a hole for fix-a-flat to seal.
the real benefit of the canned repair, and how it is generally used...is just to re-inflate the tire. a compressor will do this cleaner, and many, many times.
even if its a cheap 12v all-in-one compressor/light/jump starter box.
tuṣṭāva
