Fixing the transfer case shift motor leak from within..
Well, I finally tackled this project. To be honest, I'm a novice shade tree mechanic at best, and initially felt this was above my ability. I purchased a new actuator a year or so ago, trying to work up the courage to do it myself, or suckup the cost and have it done for me. I contacted two well known transmission shops in town, and neither would take the job. They saw what was involved, and said no thanks. Didn't even give me some ridiculously high quote--just no. The local dealership wanted $1,650 in labor alone. With the Coronapocolypse giving me a bunch of unexpected time at home, I figured it's now or never.
The initial write up is great, and I appreciate the OP, and every one else who added some advice along the way. I didn't have the leaking problem that others have had. My issue was that the actuator wouldn't operate the CDL at all, and would operate the low range inconsistently. I bought the Asin actuator from ebay--I think it was right at $500. I also bought 3 new shift rod c-clips, just in case i lost or damaged them. I meant to buy a new actuator breather hose, as mine was cracked (and quite possibly the ultimate cause of my issue) but I forgot. However the auto parts store had the correct size hose, so I made my own.
I managed to borrow a scissor transmission jack, which was worth it's weight in gold. Like some other posters here, I fabricated a jig to hold the t-case level on top of the jack. This made reinstalling much easier. If anyone is planning on doing this job and wants my jig, it's yours for free (but it's just scrap lumber that anyone could make). One thing I can add is when you get to the point of splitting the case, look at the top side, just above the front driveshaft output--there is a feature on the case designed for some kind of special tool to 'screw' the case apart. I just used a long bolt with a nut, tightened the bolt, and presto--the case splits right in half.
I wont lie--every step of the way I felt i was in over my head. But the OP is well written, and covers everything. Have the right tools on hand, follow the OP and take your time. I would estimate it took me right at 12 hours, and I wasn't in a hurry (and I changed the oil as long as I was under there).
This is a great tip! Thanks for adding the “how to” on splitting the tcase. I’ll be doing mine this Friday so hopefully it goes as smooth as what everyone says here. I’m sure how you were feeling, will be how I’ll be feeling as well.
Where are you located? If local, I’ll take you up on that offer for the tcase jig made up of lumber.
So I managed to get things back together and somehow its timed for it to be in 4hi, unlocked with no dash lights.
I do have an entire extra tcase from a V6 torn down and taking up space in my garage if anyone needs/wants any parts.
I do think that the little indicator wheels line up when the actuators are in 4lo and CDL and are at about 5-0clock when unlocked and in 4hi (actuators all the way into the case).
Seal Question
I tried to order the 15x23x7, and they're on backorder and will take 30-45 days for them to re stock. AVX seals offered to send the 15x23x5 instead. Would the thickness of the seal make a difference or should I just wait for the re stock? I live in Canada so I'm having a hard time finding alternatives.
When installing a new actuator, is there anything special you have to do as far as what setting the case should be in when installing? As in, my T-case is in 4-Hi (v8, 4wd) and I was wanting to replace the actuator. Do you need to move it to 4-Lo? I haven’t been able to find out for sure. From reading posts, it sounds like the actuators come set in 4-Lo, and when used for the first time there’s a clunk heard. After the clunk sound things work well, but I’m wondering if that’s occurring because of the mismatch.
Rocket Seals (http://rocketseals.com/) had the correct seal in stock yesterday when I ordered 2. It is part # 15x23x7-MOS-ADL. I called in and ordered, not thrilled that they were $8/ea, but my leak has gotten worse and I couldn't wait for AVX any longer (seems perpetually out of stock there).
I have torn the TC apart to replace the orings in the TC and actuator. I will be doing a write up with pictures once I re assemble. I ran into one issue upon re assembly and need some assistance. When I unbolted the first shift fork, the first large gear slide off amd I don’t know the exact position it needs to be in. There are three slots inside where some of the gear teeth are missing. I assume they are aligned on the shaft in a position that allows proper shifting and or lubrication. I know the second gear and fork (last image) are in the right position as I photographed before disassembling. Thanks in advance.
actuator
Thanks for taking the time to write this up with pictures.
I am book marking in case I ever need to replace my actuator.
Had read that replacing the actuator was a 2000$ job, but I would feel good doing it myself after seeing these pics.
Dave
a good auto trans guy here was not willing to do this one. had a bad experience
Anyone know what the part# is for this coupler on the front of the transfer case? Mine has broken and I can't seem to find the part# to get a new one. When I removed the trasfer case the coupler stayed attached to the rear of the transmission. At that point I thought it was the rear of the transmission. And was cracked and needed to be fixed or replaced by taking the transmission out. After remove the back bell off the rear of the transmission I was able to get off now just need to find how to replace it. Toyota told me it was not a serviceable part and will not give me any part #s
What my rear Transmission look like after removing the t-case
And what my t-case front shaft looks like after removing it. So you can see the first pics has the collar on the end of the shaft so it can mate to the transmission shaft.
seltzernator
