FJ Swaybars
CT-4runner
I was wondering if anyone had looked into if the larger diameter aftermarket swaybar from the FJs would fit the 4runner??
Yes looking for better on-road handling. I have noticed Cusco and Whiteline both make larger swaybars for the FJ. Anyone ever try then on the 4runner?
Keep in mind the stock swaybars on the FJ are smaller than the 4runner, so their aftermarket options may be equivalent to your stock ones. I read one calculation that stated our front bar is around 15% stiffer than their front bar. And yes both front and rear should be fully interchangeable, as long as you also order the correct size sway bar bushings.
Even before that you may want to try just upgrading your sway bar bushings to poly, that may be enough.
You also have to consider hollow vs solid sway bars. I know nothing about this in regards to a 4Runner but I changed out several on cars I've owned.
AndiGarage
