Flare Pads - Figuring out the part number, please help
subdued76
Member
Hello All,
I have searched and tried to figure out the flare pads to order them. I have a 96 4runner limited in Desert Dune with the silver cladding that runs the whole length of the truck. I have found the below part numbers that are "limited Gray." My question is; shouldn't there be three sections per side? One over the front fender, one on the rear doors, and one over the rear tire? Can someone point me in right direction? I assume the part numbers below work for both the driver and passenger sides?
53853-35030 - Wheel Flare Pad, Pad Front Wheel Opening
75767-35020 - Protector, Pad Rear Door Molding
Here's what I ordered when I replaced my 97 Limited moulding pads:
(2) 75861-35020 (gray)
(3) 53853-35030 (gray)
(2) 75767-35020 (gray)
Thank you for the response. Do you know what part the 75861-35020 was? That part appears to be discontinued. Are the numbers next to the parts the amounts you ordered?
I thought I took better photos when I redid my mouldings, but I can't find them now, sorry.
Yes, the numbers in parentheses are the quantity I ordered of each item.
You are correct, there are three of the color matched rubber/vinyl pieces on each side - one on the front fender (53853-35030, or 53583 in first figure below), one on the rear door (75767-35020, or 75767A in second figure below), and one on the quarter panel (75659-35020, or 75659A in second figure below):
However, 75659-35020 has been superseded by 53853-35030, which is the same as the front fender seal. That's why I got an extra piece of 53853-35030, to cut up and use on the rear door pieces. So you only need the two part numbers you listed in your first post.
75861-35020 is something different, it's the Rocker Panel Moulding Protector, but has been discontinued.
Thank you so much, I have ordered my parts. Thank you for making it simple!
tobasko556
