flashing 'engage to 4X4' light stuck
ozana
hi,
it seems that my 4X4 didn't engage properly and now the light keeps flashing even if the button to engage is not pressed.
i've tried to press the button to engage, to shift in low 4X4, and i even removed the negative from the battery.
any suggestions?
thank you
Keep driving it. It seems when I'm driving and push it (turn it on or off). Then let off the gas and coast it will change.
That is if it's not stuck and working properly
RIght turn = no more blinking 4x4 lite
When mine did the same when it was new to me 3 yrs ago, I learned for a 100% chance of quick engagement, I would wait until a bit before a right turn, depress button before turn, turn and during the turn it would engage. I changed diffs oil (didn't really help that) and as I have continued using the system it engages better and better to the point it will now engage without the 'right turn fix' i described. Its just the system has not been used much, drive it at least 10 miles a month in 4x4. Luck!
Maybe someone can theorize why this process works? :banana:
upanatāt
