Flush mounted roof connector
TK-422
Is anyone using a flush mount connector on the roof of their vehicle for their LED roof lights?
I know most just find a way to snake the wires into their vehicles without drilling any holes. To me that’s not the cleanest way to do it even though it avoids drilling thru the roof. I have seen others poke the wire thru the roof and seal it leaving no way to disconnect the lights for any reason.
I have on the way a 400 watt light bar on order. That should be about 32 amps. I have been looking for a waterproof 2 or 4 pin flush mount socket that can handle 40 amps and have found nothing so far. It should be something like this.
Has anyone else found a product like the picture that will handle that many amps? I have tried military, avionics and boating but none so far go more than 15 amps.
The picture above is $40 from China but does not state the amperage I only used it since it is the closest to what I am looking for.
wuddup Chris, I was thinking about the same thing. I've searched far and wide and came up with nothing so i thought about using a waterproof outlet. I was thinking about rigging up a cigarette lighter socket and make my own inline 40 amp fuse to run it. I then would cut off the plug of my led bar wiring and use a cigarette socket head end plug it into the roof mounted socket.
I wouldn't try running 32 amps through a cigarette lighter socket - it's likely to go up in smoke.
Thanks [MENTION=122831]delloro[/MENTION], that might get me a little closer.
Maybe something like this that I could fit the waterproof connectors inside.
seltzernator
