For Those Looking for a LED Light Bar
From my understanding, and correct me if I'm wrong, lumens isn't the best measurement for light bars. Candela measures the visible intensity from the light source, basically, how intense is the light when it falls upon your target. Lumens measure total light given off, but that's from the source. So, when you have the light mounted on top of your roof, are you more concerned with how much light is being generated at the LED, or with how much light actually hits your target? That's why you'll find many of the cheaper LED able to seem like they're roughly the same as your expensive brands (Baja, Rigid, etc). Sure, the LEDs may emit similar amounts of light, but how is it being thrown? The lenses and reflectors themselves play a huge role in light transmission, and by paying more, you're getting lenses that have higher transmission amounts. I have an engineer friend at Rigid who explained it to me, I wish I could explain it as well as he did.
Just jumped on the bandwagon for a 42"!
Okki
Lumens vs. Watts
Cymon is correct. Watts are a measurement of power and lumens of actual light output. Think of a regular household incandescent 100W bulb. Very bright of course. However, a newer LED version of the same bulb with same output only draws 10W. This is one of the major reasons LED light bars came about anyways because you are right, the KC Daylighter used to be unbeatable. Although, you couldn't run too many of them because they drew too much power. LED light bars, however, draw much less power for the same light output, therefore creating larger horizons in terms of available light output. I say all this to say that wattage really has no effect on light output. Lumens, although definitely not perfect, is the best way to compare light output.
appreciate the heads up [MENTION=120701]Cymon[/MENTION]!
[MENTION=123745]Sig_Fan_55[/MENTION] Which brackets are you using to mount it? looks great.
I actually just grabbed some flat steel and bent it in a vice to the measurements that made it the right hight. It mounts to the upper radiator/bumper support bar.
On a side note I didn't even click the link until just now and saw how cheap they are going for!!! I paid $200 for the 32" so this is an awesome deal.
When I look at these lightbars I always want to know what the wattage is they are putting out... if you look at the big name brands (Hella, KC HiLites, Baja Designs) they only recently started giving out Lumens as a rating, lumens are really one of those subjective measurements because its a claim that most people cant actually measure.
One of the brightest lights used to be the KC Daylighter, it was a single 150 watt light.
a 42" light bar from Opt7 is only 288w and this Generic 42" lightbar is 400w
Its a little more expensive BUT I can tell you the difference between a 100w light and a 150w light is HUGE.
Problem is many of these generic light bars are becoming like cheap car stereo amplifiers 2000W for $23.99 at the flea market while a 500W Alpine will cost $450.
In addition some of them will say Cree or Philips LEDs while in fact they are knockoff or counterfeit LEDs. I work in the manufacturing portion of electronics in China and we also build LED lighting, have actually built for Cree previously. Run into it all the time. This is why I tend to look at the reviews on Amazon carefully as they really tend to be the only feedback mechanism we have access to before purchasing the generic bars.
As for the big guys putting lumens it is a very measurable characteristic and a good indicator of what the a fixture is putting out. It is just something we can't easily measure. Just fyi, nothing more.
This would be an awesome test to have, to get a few of these light bars, Opt7, KC, Rigid, and Generic and test them all to see which truly is the brightest.
Rigid has been ripping people off for years,... and now its coming back to bite them because they had china make the light bars and if there is anything the chinese are good at its copying things. Anyone who has been to Hong Kong knows this first hand.
If you had any more details, and/or pictures of this, that'd be great. I'm going to be doing the exact same thing.
Amazon seems to be having some pretty good deals on the OPT 7 LED light bars. I've been eyeing the 22" for a while to hook up as a "behind the grill light" using the brackets I got from [MENTION=133346]BradBrad619[/MENTION] as it seems to be a good "bang for the buck" light bar. Its no Rigid or Baja Designs but does get solid reviews and at the current $58 price and includes the 380w/40 amp wiring harness/relay. The cheapest I've found this combo before is $90 (the current price on eBay) for the light bar and $25 for the harness, so essentially it is 50% off.
I wouldn't have bought it without some research and recommendations from forum members that I respect, like in this thread by [MENTION=83083]rigtec[/MENTION] .
http://www.toyota-4runner.org/5th-gen-t4rs/178040-opt7-leds.html
Just wanted to share in case anyone else is looking, the 32" Light bar also has a good price (harness included).
The Link!
https://www.amazon.com/s/ref=nb_sb_...automotive&field-keywords=Opt+7+led+light+bar
Sweet thanks
Thanks for the heads up.
This is a great deal, was planning to buy one at the regular price, now I can buy a extra one.
I have this exact 32" opt7 light. It's a great light and haven't had any problems with it. The output is phenomenal, don't own any rigid a or Baja lights, but for my needs it is perfect.
Just ordered 3., will use 1 and give the other ones as gifts.
Do you need me to PM you my address? I am up for Christmas gifts in July!
While we're kinda on the subject......driving around in daylight with a 42" light bar on full blast, strapped to an old beater and trying your best to blind oncoming traffic makes you a mega-douche. Hopefully this is just a CO phenomenon because seriously WTF?
Useless rant over, carry on.
Is it easy to install?
Heck I"m doing it...LOL
Here are some of the many resources I'm using from the helpful folks of this forum...
Hooking up Opt7 Light Bars
http://www.toyota-4runner.org/5th-gen-t4rs/178040-opt7-leds-6.html
Using AOB Switches
Everyone...
http://www.toyota-4runner.org/5th-gen-t4rs/211802-wiring-lightbar-independent-harness-aob-switch.html
Behind the Grill Setup:
[MENTION=103267]Saker[/MENTION]
http://www.toyota-4runner.org/5th-gen-t4rs/164966-led-light-bar-install-2014-toyota-4runner.html
How to get through the Firewall:
Everyone....
http://www.toyota-4runner.org/5th-gen-t4rs/120835-cable-routing-through-firewall.html
[MENTION=65614]Antman[/MENTION] (Check the subwoofer install to see how to route through firewall)
http://www.toyota-4runner.org/5th-gen-t4rs/92013-antmans-thread-24.html#post989173
Drive north. Apparently every mega douche in Wyoming has upgraded their awful diesel trucks to include multiple light bars that are on constantly. Sorry to hear that this douche disease is widespread.
That same mega-douche from CO, as well as his buddies from WO, must have come here because it's the same down south.
WAIT !
There must be a magazine or a forum for the mega-douches that suggests, NO, requires them to do this!
:doh: :faint:
:focus:
The Link!
https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dautomotive&field-keywords=Opt+7+led+light+bar
I have the 32" in my grille and it is absolutely worth the price and a great value. I have had zero issues with it and I've been running it on the front for almost a year now.
2001ATL
