Fox and Radflo Coilovers (2.5" dia / 600 lb coils)
Bicepus Maximus
Almost ready to buy one of these. But I can't find any feedback from anyone outside of [MENTION=74569]SOcalTRAIL[/MENTION] who runs (or has run) these shocks.
I would get them with 600 lb coils. Hopefully someone runs either of these setups and can provide some feedback on their experience?
Thanks in advance.
I am happy with my Radflo setup. Going to be getting it rebuilt soon. I run the 2.5 setup with 700 lb springs.
No experience with fox though.
I run Radflo but currently have only the 2.0" shock body, so no helping you there. My spring rate is 650 lbs though. I have been pretty happy with the Radflo set up I'm running right now. I will most certainly upgrade to the 2.5" shock bodies when I decide to revamp the suspension.
I just did all four corners - Radflo 2.5/700... runs about $100 each +/- for the rebuild and additional if you add anything/replace items.
Going to be adding remote resis with adjusters while I am at it too. Already been in contact with then regarding. Just figuring out finances for other things first.
If adding a winch up front than should consider 650 lbs. If a bumper than 700 lbs. I'm running OW Radflo 2.5" with 650 lbs with no complaints.
Ordered the following:
LR UCAs
Fox 2.5" coilovers (non-resi) c/w 600 lb spring
Fox 2.0" rear dampers (non-resi)
All-Pro 2" lift rear coils (used)
No Fox retailer/dealer near me has stock. Should be here in a couple of weeks.
Maybe I'll do a build thread and post some pics and my review in there.
Only option Fox has for the 4Runner. They don't make 2.5s for the rear. I talked to them in the past and they told me 2.5 rear dampers are overkill for this type of vehicle.
increasedc
