Fox suspension?
anybody compare the Fox 2.5 remote front coilovers with DSC adjusters to the King 2.5 coilovers with adjusters? Fox used to be a little cheaper but they are almost identical price to the Kings.
Truck in questions is a 18 TRD w/KDSS. Will also be running the Camburg ball joint or uniball upper control arm and SAW or Toytech rear springs.
Go with Kings, Fox has exceptionally poor customer service.
What does the bottom mount looks like for you guys? apparently mine is weird looking and the back of the mount is rubbing again the tab on the lower control arm, attached is for driver side, passenger is not as severe but is pretty close.
So I just picked up my 2018 SR5 and want to address the suspension. I'd like to do the following:
1.)Stop the nose dive under breaking
2.)Lift the truck 2"
3.)Be able to fit 275/70/17 ( Any make )
4.)Might add a small spacer in rear in the future to address the roof rack, car top tent and other weight
5.) Avoid the need for Upper Control Arms for proper alignment
6.) Be able to soak up washboard and desert roads while maintain an enjoyable ride on pavement (90% on road driving)
Here's wha I have found:
SuperFlex 2" Rear Coil Spring Pair for 2003+ 4Runner, 2007+ FJ Cruiser (RCC2.0)
Fox 2.0 Performance Series Remote Reservoir Rear Shock Set with CD Adjusters for 2003+ 4Runner, 2007+ FJ Cruiser (985-26-117 x2) or
For 2"-3" Rear Lift (FRS 985-26-118 X2)
Fox 2.0" Performance Series Front Coilover Set (983-02-051 x2)
I'd get the 2"-3" rear shocks in case I add the spacers. Would i need anything else like a diff drop kit or anything?
So happy to find this forum and the helpfull community.
Cheers
What did you end up going with?
I ended up going with the Bil 6112 (7,5) 5100, T13 setup. Very happy with the amount of lift and the overall ride. The lift 2.5" in the front and 1.5" in the rear. For the money you can't go wrong, think it cost me right at $1k. UCA's will be coming soon to help with the alignment. IT's not bad, but could be better.
My main issue with going the Fox route is the requirement of rebuilding the shock at regular intervals. I put close to 40k miles on my truck every year, soI'd be looking at downtime every 12 months or so.
I think the need for rebuilding is way overblown. Fox and other shocks use as good of seals as exist. I'd guess less than 1% are ever rebuilt after they leave the factory.
The one part that does need periodic replacement is the spherical bushings (uniballs). IMO they really are a pain in the ass that serves no functional purpose in these suspensions. We don't need high misalignment spacers. Rubber would be a better choice. That said, I have personally seen a rear shock come off the rubber bushing. It didn't unbolt - the rubber couldn't flex enough for the articulation and the rear shock eye came off the rubber. Nothing broke. We just hammered the rubber back into they eye and bolted it back up. But that's the limitation on rubber. For us - It's not a problem. No 4Runner suspension has enough travel to matter - other than maybe RSG's? Anyway - they're $10-15 ea and generally only need replacement on the lower end, not the uppers. But it takes a few hours to swap them. I've replaced the lowers once. They were a huge PITA because they were seized up to the bolt so I had to cut them apart to get them out. With a bunch of anti-seize, now they're a breeze to remove. I usually take them out 1-2 times a year for other messing around with the suspension. Normally pulling out the front coilovers takes about 20 minutes /side. If I'm adjusting height more than a little bit - I just pull them out and do it in a bench vise.
The bilsteins will probably last about the same as a rebuild cycle of FOX. The difference is that you throw away the bilsteins and you rebuild the FOX ones. Given the price difference - it's probably a wash price wise.
The primary benefit of the Fox/king etc. is the valving options. I've been waiting for a chance to have mine rebuilt - but the primary reason is that I want the valving changed to a flutter stack. I'm not sure many people ever actually rebuild them for reasons other than changing internal parts to adjust the dampening.
Looking for some setup advice from users.
I'm having fox 2.5 dsc coilovers (front) and 2.0 shocks w/adjusters installed with OME overland springs on my 5th gen w/kdss. Questions for those who have done the same:
Am I correct in reading that FOX doesn't have any custom valving for this vehicle and it's all the same out of box?
If that's the case what base settings from fully closed (clockwise to counter) are people running if at all?
I'm having a fox 2.5 dsc and 2.0 w/adjusters installed with OME overland springs in back installed on my 5th gen w/kdss. Questions for those who have done the same:
On the street I run both clickers at full soft.
This is interesting. I come from a mountain biking background and when climbing fire roads we have fast settings to effectively put high and low speed compression to fully closed (firm) positions for efficiency. Then when descending we adjust towards the soft end depending on the bike/desired feedback and tracking needs. So you head towards firm when off-roading? Do you mind if I ask what settings (high and low speed) you like when off-road?
I really don't have any base settings, as we are always in different terrain. I start a couple clicks out based on the speed of the trail and then start messing with compression and rebound every mile or two.
I'm curious why no one is running the fox suspension. It seems like icon is the choice for most of the members when upgrading. There are a lot of toytec (which I have), OME, and tons of icons, but no fox. Is this just preference or does the fox suspension not work as well with our trucks?
New member here. Haven't hit my reply quota to post my own thread. This one seemed to be the best fit. Hope this doesn't come off as a thread hijack.
I have a '19 TRD Pro (Fox Shocks are OEM on this model/yr). I'm getting the below list of upgrades installed and got to wondering at what load capacity should I consider upgrading the suspension?
It's worth noting I plan on doing only light offroading (logging roads etc) but with an additional 700 lbs of people, dog and gear onboard when I do.
All in it could be up to 1,185 lbs of added weight.
Upgrade list w/ weights
  • Prinsu Full Roofrack +75 lbs
  • CBI Sliders +140 lbs
  • CBI Rear Skid Plate (alum) +50 lbs
  • SSO Hybrid Winch Bumper (alum) +40 lbs
  • Warn Winch (synthetic) +30 lbs?
  • Truck Vault drawer system +130 lbs
  • ARB Twin Air comp +20 lbs
The front will definitely be sagging a little with the added bumper and winch. I'm not too familiar with what they offer along with the OEM Fox shocks but if heavier springs is offered, definitely look into getting. If not, aftermarket. As for rear, heavier springs.
FYI warn winch will be good 50+ lbs if your getting a 10 or 12k even with synthetic line.
Sent from my SM-N970U using Tapatalk
Thanks I was afraid of that. Looks like another upgrade or 2 will be added to the list.
You can calculate the height change from the added weight pretty easily.
In the front the OEM springs are about 550lb/in. There's 2 of them but they have a leverage of 2:1, so effectively the front suspension has a combined spring rate of ~550lb/in. If you add 225lb to the front, it'll sit about 1/2" lower. If you add 550lb, it'll drop 1 inch.
In the rear all 4Runners (except limiteds) have 180lb/in coils stock. And there are 2 of them, but no adjustment like the front, so combined the rear suspension is 360lb/in. If you add 360lb to the rear, it'll go down 1".
So you can calculate from there how much it'll drop depending on what you do. There are two factors that will change height - taller springs or stiffer springs. You can choose the combo that works best for you. For off road performance - it's almost always better to have a longer softer spring than a shorter stiffer one. For the ability to haul a lot of weight, then you would tend toward the stiffer spring. So you'll have to compromise with any choice between weight carrying ability and giving up some comfort.
That's why we typically end up around 600-650lb springs in the front or a little higher. That's about the sweet spot for performance and ability to handle changes in load without too much sag. In the rear, it depends again on how much you want to haul, but around 200-250lb/in is tends to be as firm as you would want without being harsh unloaded.
So... you should decide what ride height you want empty, how much weight you'll likely be carrying loaded up, and then decide what spring rates and lengths you want to match what you're wanting to do.
A lot of people use air springs in the rear to help with the extra load when they're going for extended trips with a lot of weight. I have run a couple different air spring alternatives. IMO - if you do it, I'd spend the extra few $ on the firestone set over the airlift. The firestone bags are narrower and cause less binding on the coils when empty. Both work about the same with a load.
Lift advice
Hi Everyone,
I'm new to this forum and haven't owned a 4runner until this week. I just purchased a 2020 ORP and am considering my lift options. I was looking at the Fox 2.5 coilovers and 2.0 rears with ICON springs and Camburg UCA's. I'm going to be perfectly honest and say I really don't plan on doing a lot of off-roading, although I have a few trails near my home. Is this setup overkill?? Should I be considering the Bilstien 5100 setup and spacers that seem to be fairly popular?
Any advice is greatly appreciated.
Hi Everyone,
yes save yourself thousands and do the 5100s or maybe spring for a dobinsons set up
Thanks @ tm965 I like the idea of saving thousands. I appreciate the advice!
Thanks [MENTION=318203]Ryan at Eibach[/MENTION], I'll surely look into your lift.
Hi Everyone,
It's overkill for what you are going to use it for. The stock set up is very capable as well and you might want to just try that before deciding to drop any cash.
I had the 5100s all around with Icon Springs and do a fair bit of trails and rocks and just upgraded to the Fox 2.5 DSC, and Icon UCAs Delta Joints (Camburg was out of their version and only had uniballs) and it's riding nice for what I use the rig for.
You don't need the FOX (or ICON or King, etc) if you're just on normal fire roads, dirt trails etc, and the stock set up might even be fine, or just blow it out before you upgrade it.
