TheDurk
Elite Member
T-post driver as a cheater bar. MacGyver would be proud.
Sent from my SM-G930T using Tapatalk
Couldn't find the pipe I normally use and the driver was handy.
A retrieval tool possiblyVery impressive. I would have gotten another 3rd gen and called it a day.
I love the ingenuity with the logs and other non normal frame off body proclivities though the rake in one of the pics is baffling in its use here.....
A retrieval tool possibly?
Sent from my SM-N900W8 using Tapatalk
If you've owned a truck for 17 years, it's hard to go buy one that some idiot has maintained and deal with nasty surprises. I fought hard to get an IJM 5-speed 17 years ago and I won't settle for anything else. (I wish I had known what a locker was, or I would have gotten that.) This truck has been stone-cold reliable since new, and I think it deserved this effort after all we have been through together,
Awesome job man! That was a beast of a project. You deserve every bit of that victory lap to alignment shop. [emoji41]Just got back from a TEST DRIVE!!! She rides again. My gut feel alignment was amazingly good--cant wait to see the sheet at the shop to see how close. But it didn't pull at all or feel anything but normal. 'Truth is, I noticed that all the cam bolts on both the old frame and new frame were set at 12 o'clock exactly, so I did the same. And the TRE's are as close to 1mm toe-in as I could get with a tape measure and two yardsticks clamped to the rotors. I think it's a little more than that, but it won't shred my tires in the four miles to the shop. The rag joint I set to my paintmarks I did when I took the frame off, and the wheel still tracks straight.
Tomorrow I will put the front driveshaft, swaybar and bumper on, and give it a good pressure washing. There are anti-seize fingerprints and smears everywhere. Then I'll take some nice pics on the lift at the alignment shop which is booked for Thursday.
Now I get to add up all the bills and see what this adventure cost me. Pretty sure it's less than welding up the old one, and now everything underneath is solid, POR15'd, anti-seized, and torqued to spec. Glad it's over but I'm glad I did it.
I did set an ABS light, and I think it's because one of the rear sensors didn't go in all the way. Probably some POR15 in the hole. So I get to try out my pirate Techstream rig that has been sitting around waiting for a moment like this.
Well, I just wanted to record a (slightly) interesting factoid. I am replacing the fuel pump and in-tank filter while I have the chance, and will also paint the tank, so I had occasion to measure precisely how much fuel is left in the tank once the fuel pump sucks air. I'm sure there are a number of variables, but in my case, there was almost exactly 100 oz. left in the tank when I propped the tank on end and siphoned out the last drop. Call it 4/5ths of a gallon. Some have posted it is as much as 2 gallons and I have always doubted that was true.
I'm also going to trim an inch off the vent pipe to bring my '99 more in line with other years. This should allow me to get more than 12.5 gallons in on a fill up.
