Frame rusted thru - patch weld options near Chicago?
jerkstore
So I bought my first 4runner 2 weeks ago. The truck spent its life in Michigan and Chicago. The underside didn't look too bad compared to other trucks i have seen during my search so i went ahead and bought it. It has all the maintenance records and has had a decent life. I just did a tune up (plugs, wires, air and fuel filter), changed out the front sway bar end links today, and my bilstein 4600s arrived in the mail today. I got under it and checked the inside of the frame by the muffler and F***......
Anyone know a shop near Chicago that does patch welding? I definely stuck my finger thru the frame and not thru the holes that are suppose to be there...
It isn't a huge area. It seems pretty solid except right by the muffler. I'll get some pictures in a minute, its dark outside now though so they might not be the best.
all her glory
2015-05-04%2022.05.09.jpg~original
Question for all you in the know - does Toyota sell those frame "horns" that the links bolt to?
If so I'd buy those, cut out the rust and patch it and then weld the new pieces in.
Thats not too bad. Completely repairable. Put on a nice muffler while you're at it. Check out the jeep wrangler forums for their rust repairs. It will make you feel better :cheers:
If you go to a frame shop they'll do a great job but charge you a great sum of cash. I went to some good ol boys welding place (in indiana) and they said they'd weld mine up for $200, including plasma cutting away the rusty sections. I eventually found a friend of a friend that is retired and builds cars to do it for $50.
That's a common spot for rust on these rigs because the heat from the muffler gets on the salt and accelerates the process. My frame on my rig has no serious rust except for that spot. Found it, cut the muffler, welded it, and bought a new muffler. Wasn't too bad, I probably paid $150ish for a solid job.
Mine looks worse than yours was. Pretty safe now. Link to specific post and pictures:
http://www.toyota-4runner.org/3rd-g...-introduction-build-thread-8.html#post1367140
Do you remember where that good ol boys welding shop was?
OP, take it how you want, but I will tell you straight up- that frame has multiple years of salty winters left in her, yours is one of the better frames I have seen in the SE Wisconsin area. Check out my build thread (first page, link below) for some pics of DIY weld work; one night in the shop and it will be good ( probably better) than new.
Those brackets are available on Toyota parts deal for around $60,but you have no reason to replace yours.
If you ever came up north of the Milwaukee area, I'd fix it for ya on my lift for cheap. :cheers:
erinobr2000
