What are you guys using to seat the front cv seal? Dealer denied warranty coverage on both leaking seals. I replaced both and the passenger is still leaking. I just put them on the axle and put them in. what commonly available item would be suggested to do this right?
Amazon.com: 10 PC Wheel BEARING RACE SEAL Driver Axle Installer Insertion Collar 1.56-3.18: Automotive
I bet your not getting the seals into the housing far enough. I usually use a hammer with light taps.
I would check the CV boot itself as the leaking oil usually comes from there. The bearing inside the hub is a sealed bearing and there should be no grease leaking out from the seal where the CV goes through the hub/spindle.
I just changed left and right hub bearings on my buddys Tacoma yesterday and have done it a few times before on FJ Cruisers, even though the bearings were bad there was minimal leaking going on inside the hub where the bearing is and not nearly enough to spill out through the seal.
Unless I read this wrong and you are talking about the seals on the CV side that go into the front diff?
yes, that is correct. the boot is fine and is not leaking grease. It is leaking diff fluid through the seal that the axle goes through into the diff.
I am getting pretty good at pulling the axle out now. Found a kit similar to the one posted above and set to putting a new seal in the other night. I pushed the seal in as deep as it would go as per some posts I read and bolted everything back up being especially careful not to mash the axle into the seal as I inserted it.
I don't know what is up with this seal but it is now leaking worse than before. It is dripping every few seconds once the vehicle stops moving.
Any tips or things I should look at? Dealer denied warranty coverage because of the lift so I do not want to take it back there. Figured this should be pretty simple.
I also replaced the driver side and it is holding up fine. I think the leak started when I was a little over zealous pressure washing it after my last 4x4 trip in June.
what about the depth the seal is seated to? first time i seated it with the axle, second time all the way in....what am i missing?
Just curious, but under what premise did the dealer deny coverage?
You went to far in. There is a happy medium that the seals has to go in to seal correctly. Usually it's flush with the inner lip of the housing.
