front strut/spring issue???
ColoMike01
The top and bottom mounts arent lining up properly, if I install the top first the bottom is slighltly off and needs to be rotated less the a .25 inch. Is there an easy way to do this with having to disassemble? I dont want to just wedge it in there.....
Thanks, Mike...
Thanks, Mike...
Rent spring compressor from local auto parts. Once springs are compressed a little you can simple turn the shock without disassembly. I learned this since toytec sent mine to me misaligned.
With the top plate nuts installed, you should be able to just use a large screw driver, pry bar, etc. and turn the strut where you need.
31ectr0nicb0b
