Front Wheel Bearing DIY
Well, this is totally ****ed.
Not how to do it at all.
Horrible advice.
Cool write up. This thread has been added to the Tutorials & FAQs list. I only randomly stumbled across this thread.
3rd Gen FAQ, Tutorials, & Documentation Reference v2 - Toyota 4Runner Forum - Largest 4Runner Forum
Brian, I really think you should reconsider keeping this write-up in the Tutorials and FAQs list. Do you really want to some poor dude to take a reciprocating saw to his hubs? This write-up is not worthy of passing on to other people. Sean and I go through great pains to give people good video tutorials to follow and we always try our best to not pass on inaccurate information and/or showcase improper techniques. If we find a mistake we've made or somebody has pointed out a mistake, we correct it.
Jesus christ....this was a perfectly fine writeup until the part with the sawzall lol!
So assuming one was to follow the proper way of pressing everything out with a press (which is the hardest part about this job), what is the minimum size press that's enough to do the job? Would 20 tons be enough?
Yes, a 20 ton press does the job just fine. I used a Harbor Freight 20 ton press to press out front hubs and wheel bearings 3 times.
Thanks guys for the feedback! It's an opportunity to learn, and I appreciate the links and videos shared. I'll just keep taking a sawzall to the rest of my rig in the meantime. Cheers. :becky:
Yup! That free spins with play.
Mine doesn’t spin when i putted back together.
It was a little difficult to put te abs rotor (it didn’t passed free the first hub bump) once it passed it was free.
The problem was when I re assembly the spacer, this one never felt free spin.
I don’t now if is q life death situation because when you put back together it will be lock because the tork of the cv axel nut.
Start over will cost me a new bearing, new hub (preventive), new spacer and new abs rotor because i don’t know what is making the spacer don’t freely rotates with play.
Sorry about my english, I am an italian leaving in Miami and new arround here.
Thank you
Thank you
If your saying that the hub doesn't spin then you most certainly did something wrong. The only part you would need to replace again if you took it apart would be the $60 bearing. (that's what I paid 3 years ago so it probably a little more)
I know this is an old thread, and I also know I have not written in this forum for a long time. However, I still read it.
I just wanted to quickly add a few things from my experience. I just did this job two nights ago. It took about 3 hours. I thought it was relatively easy.
-First of all, I think this video is extremely helpful: https://www.youtube.com/watch?v=LId0MgZ37OA
-I used the hub assembly from Bluepitbearings.com. I know it is on the expensive side, but he uses quality materials, has excellent reviews and his turnaround was immediate. I contacted him on Thursday, he got back to me right away, placed the order on Thursday. Had the hubs delivered on Monday, and replaced on Tuesday (one side).
-The only comments I will add to the video are:
--Don't hit the axle with the nut to hard because you can damage the outer thread of the nut. It happened to me so I had to spend some time with a file fixing it. Or just make really sure that the nut and axle are flat and you hit flat as well, of just place a piece of flat steel in between.
--When removing the bearing, in my case, I was beating the hub very hard back and forth, but it was not moving. Then I grabbed one of my big bearing pullers and it worked like a charm. The puller is from the Harbor Freight puller kit, nothing to fancy.
That's it. Without the small issues above it would have taken me 2-2.5 hours, including setup and cleanup.
I gotta say. That I’ve done shit like this before. However I didn’t have a press. But this was the best. As you kept scrolling all of sudden you see OP with a press. Then your like... huh? Lol.
it looks like they don't have a bearing for 3rd gens just 4th and up. Bummer
The video above and the link above are for 4th gen and up. The bearings and hub on a 3rd gen are pressed into the steering knuckle and infinitely harder to remove than 4th gen. The bearing themselves are pretty cheap but there is no way around not needing a press. If someone has managed to do this any other way I would love to hear it. I think mtbtim's video is the best portrayal of what it takes (even though they're swapping hubs). I ended up taking my knuckle assembly to a machine shop and having them press it out. He told me they had to use 30t of force to press the old one out on one side...
Just did mine today. I was able to reuse everything but the new bearing. I know having a press is not reasonable for everyone but it does not cost too much to have your local machinist press it in and out for you.
A torch and a saw or not on the list for the tools I want to whip out unless I absolutely have to
But great write up
1999 Limited 2WD
Hi,
Is the 4WD hub assembly and bearing compatible with the 2WD hub assembly and bearing?
Seems like there are complete assemblies for the 4WD but not the 2WD where the bearings are already pressed in.
For those of us who don't have a lot of time or tools, does anyone sell a complete like... Hub/bearing/knuckle?
it's definitely not as simple as the bolt on one the 2nd gen tacos have, haha.
The knuckle itself goes for about $400, the rest of the parts required add up to $200. So you're looking at $600 per side, for parts alone.
I wondering if this is something that might be ok to buy used. Maybe not from a pick and pull, but someone parting out a truck that you have reason to trust.
charlesz
