Entropy85
FS: 1989 Toyota 4Runner SR5 4x4, Colorado Springs, CO -$3000
For sale I have my 1989 4Runner SR5 4x4. It is the 3.0 V6 with a 5 speed manual, and it has just under 293,000 miles. Here's the good and bad....
The Good:
-Head gaskets replaced at 250k
-Timing belt replaced at 276k, as well as all engine seals and gaskets.
-Brand new alternator and battery
-Fuel pump replaced at 288k
-New clutch master, clutch slave, and clutch hose
-New front axles
-New front brakes
-Headlights upgraded to H4
The bad:
-Small exhaust leak
-Distributor O-Ring leaking a little
-Drain plug on front axle carrier leaks a bit
-Needs windshield
The 4WD works great, it shifts smooth, and doesn't overheat. Starts every time you turn the key, and the A/C and heat both work great. Interior is clean with the exception of the cracked dash, body has minimal rust. Power everything, everything works. I would take this truck anywhere, however a change in my life dictates that I probably should sell it..... I'm asking $3000. Thanks for looking! I'm located in Colorado Springs, CO, about an hour south of Denver.
The Good:
-New front axles
-New front brakes
The bad:
-Small exhaust leak
-Needs windshield
