FS: 1st GEN 1986 Toyota 4Runner DLX - Blue $4500 LA-CA
astroAK
For Sale $4500 obo. Thanks for looking!
About the Vehicle
Exterior: Paint 6 out of 10 condition with dings, bubbles in a couple of parts with minor surface rust over driver window and over passenger wheel. Removable top faded. Rims have some knicks, possible from off road. All lights work. Lower gas door hinge broken. Back window works completely but at times you have to mess with the back wiper blade for the switch inside to roll the window down.
Interior: Before my plan to sell the vehicle I wanted to clean up the interior. Since the interior was not original, I was going to do it the way I wanted. I painted the dashboard grey and repainted the black areas. Center console repainted black. Shifter boot cover replaced. Dash is cracked in one spot and I tried to fill it myself. *NO A/C* but working Heater. Odometer reads 226k but last seller says its a rebuild at 60k (no proof, unfortunately)
Maintenance
The vehicle was purchased and repaired in March 2014. Have all receipts for the following work.
The following serviced by Green Drop Garage Portland, OR
New Tires
Oil & Filter
Oil Drain Plug
Brake Disc
Brake Pad Set - With Shims
Wheel Seal - Front Wheel
Thermostat
Thermostat Gasket
Water Outlet
Ball Joint - Lower - Front Suspension
Ball Joint - Upper - Front Suspension
Brake Drum - Rear
Brake Shoes - Rear, Ultra Premium
Brake Shoe Hardware Kit - Maxi Pack - Rear
Wheel Bolt Nut
Replace front disc brake pads and rotors and repack wheel bearings
Replace Thermostat and Housing
Front End Alignment
Replace both Front Upper and Lower Ball Joints
Replace Rear Brake shoes
New Lug Nuts
The following was serviced by Kendall Toyota, Eugene OR.
Distributor O Ring
Valve Cover Gasket
The following was serviced by Yorks and Lancs Chatsworth, Ca
Reseal Oil Pump
Camshaft Seal
Alternator Belt
Timing Cover Gasket
Air Filter
Tune Up
o2 Censor
Also replaced
70amp alternator
Rear drive shaft U-Joints
Planned repairs
Rear leaf springs
Header gasket
CV Boots (left right)
Exhaust (upgrade)
Redo sun visors (I have the frames)
Re-installed the center console with new boot cover (I repaired the cracks on the one that goes around the shifter but needs to be re textured)
Passed smog and registered in CA with tags. Registered until March 2015.
Bunkstaff
