FS: 2000 4Runner -- E-Locker -- SUPERCHARGED & SMOGGED $13,500 Bay Area, CA
regulator213
THE UNICORN -- SUPERCHARGED 2000 4Runner limited with FACTORY E-LOCKER. This truck has been my daily driver for several years now and I love the truck. I built this truck sparing no expense to be dependable on and off the trail. I originally intended for the truck to run trails however I have ended up just using it for camping and I don't feel the truck is being used to its full potential. I'd love for this truck to be in the hands of someone who will take care of it and use it like it was intended.
The truck has 219,xxx Miles on it and runs solid. It is a California spec truck with NO EGR SYSTEM. This truck is truly a one of a kind. I have all original keys/key fobs, owners manual, AND THE WINDOW STICKER.
- OEM water pump, timing belt, and all accessory belts changed at 186K
- All fluids changed to Mobil 1 (transmission, transfer case, front and rear differential, engine)
SUSPENSION/WHEELS/TIRES
- Goodyear Wrangler 265/75-16 tires with approx 50-60% tread life left on them
- Toytec 3" suspension lift -- Bilstein & BOSS shocks
- 1" body lift
- Freshly powder coated 4x Innovations rock sliders with kick out ready to be welded on
- New steering rack with polyurethane bushings
- New inner and outer tie rods
- New OEM lower ball joints
- New OEM lower control arms
- Upgraded sway bar end links
- New polyurethane sway bar bushings and end link bushings
DRIVETRAIN
- Upgraded transmission valve body and accumulator springs from Import Performance Transmissions (protects transmission from extra torque due to supercharger)
- Balanced and rebuilt front and rear driveshafts with new U-joints and Double Cardon from Driveline Service of West Sac
- Factory E-LOCKER with blue wire mod
PERFORMANCE/ENGINE
- Magnuson supercharger - 2nd Gen (Black) - 10K Miles - With CARB sticker
- Magnuson superchargers sticker (Adds 15 HP)
- Air Raid intake tube - with CARB sticker
- New Denso Iridium IK22 spark plugs (2 step colder)
- URD 7th injector with AIC piggyback
- New Walbro 190 LPH fuel pump
- URD 2.2 Pulley (not installed)
- New Cometic MLS .080 head gasket (gets rid of 4th gear pinging)
- ARP head studs
- URD full O throttle body gasket
- New gaskets and o-rings from head all the way up to throttle body
- Heads/valves pressure tested for valve seat with no leaks
- Gibson catback exhaust
LIGHTS/ELECTRONICS
- Innovate wideband O2 sensor
- Autometer boost gauge
- 32" curved Cree LED light bar on bumper
- 50" curved Cree LED light bar on roof (both wired to "Sasquatch" switch)
- Sony MEX-XB100BT head unit - bluetooth - built in 4x100 Watt amplifier
- Kicker 2 way door speakers
- Amber LED Parking lights
- 1800 LM Reverse lights (helps greatly with backing up in dimly lit areas)
- Red LED map lights (helps preserve night vision, especially on dark roads)
- BRIGHT LED dome and trunk lights for normal use
- Optima red top battery - 6 months old
Asking $13,500 CLEAN TITLE IN HAND
hey i have a 2000 limited too and I was just wondering how much the supercharger affects mpg's? any Idea what you get with this beauty?
Anyone else having trouble seeing the pics?
It might be because I'm at work but none of the photos are showing up for me.
NVBASSJUNKIE
