FS: 2000 Toyota 4runner Limited Lifted $8000
zRus13
2000 Toyota 4runner limited 3.4L 200,720 miles REAR DIFF LOCK!! with green wire mod Keyless entry Avital remote starter system Spectre drop in air filter Custom deckplate mod Cat back stainless steel exhaust Powder coated wheels (mirror black) Husky rear hatch liner to protect floor Kenwood touchscreen radio and DVD player with Bluetooth streaming audio Cobra color changing cb radio(may or may not come with runner depending on price) Firestsik cb antenna with insain fab mount 40 inch led light bar with nice switch inside 3inch rough country suspension lift 2 inch toytec body lift Platinum AGM battery New shocks in front and back New brakes, rotors, and drums New backing plates, axle seals, and front axles Both new denso oxygen sensors New Toyota timing belt, serpentine belt, idler pulleys, Toyota water pump, radiator, and Toyota red coolant Fresh oil change Brighter headlight bulbs installed along with new wipers Transmission shifts beautifully Cold air conditioning and hot heat Honda steering wheel cover (adds 50 horsepower!!!) Interior is spotless Depending on sale price runner also comes with spare set of Toyota Tacoma base model rims with tires (never mounted on runner) Also spare set of new 255/85/16 tempra trail cutter rt tires with studs (have about 3000 miles on them only ran for winter tires) Tires on vehicle now which are stock size 265/70/16 cooper discoverer at3 that are at about half life I love this thing and have taken care of any flaw and maintained it very well. I should have receipts for just about all the work done to it if you would like to see it, would just have to find where I put the others. The only reason I'm selling is because I need a truck because I always need to haul things and pull heavy race trailers that haul my Dirtbikes, car and other toys which unfortunately usually weighs 3 times the 4Runner:/ I believe I got just about everything if you have and questions please feel free to call or text me at 814-289-6524 thank you!
erinobr2000
