2005 Toyota 4Runner SR5 V8
213000 km
White, gray cloth interior
Non-smoker, no accidents
Montreal, CANADA
$6500 Canadian
This 4Runner is in good condition and is an excellent platform for building up the overland machine of your dreams.
More pictures to come.
The Good
- Motor and transmission in perfect running condition
- Timing belt is good for another 50000 km
- No cracks in the exhaust headers, no oil leaks
- Well maintained with many receipts available
- Front calipers replaced in 2016, front CV shafts replaced in 2017
- Motomaster AGM battery in 2016
- 5x Cooper Discoverer A/T3 on mags 265/70-17, 4x Toyo winter tires on steel wheels 265/65-17
- Paint in good condition with some light trail pinstriping, and some heavy scuffing/cracking on the plastic panels
- Clean interior
- Full RCI skid plate kit installed, non-painted
- Includes Shrockworks rear link skid kit - not installed
- New latch motor for rear hatch in 2016
- No XREAS
- LED exterior bulbs (signal, marker, tail/brake, reverse) from https://www.superbrightleds.com
- Secondary 8-circuit Blue Sea 5046 fuse panel installed under the hood
- 2x Blue Sea 1049 dual high-power USB chargers
- Uniden Pro 510XL CB radio, hardwired, with Wilson Little Wil mag-mount antenna
- Lots of great stickers
The Bad
- The suspension is starting to get clunky - the rear shocks need new bushings at the very least.
- 2 years of trail use have left their mark - the underside shows the evidence you would expect on a truck with stock suspension. Nothing is broken, just banged up.
- A speaker in the driver's door no longer works.
- Evidence of a small exhaust leak under full throttle, but quiet with normal use
- The rear hatch is rusting from the inside-out, as is normal on a truck with this age. It shows some bubbling in the paint and some reddish traces, but the door is still solid.
- Lighter circuit is dead, including rear socket
