FS 3rd gen 1996 limited $1200 in CT
sean2202
Selling my 96 4runner limited for parts repair or for off road. Body is in very nice shape with the exception of some minor hickory nut damage on hood and roof. Engine and drivetrain has 210,000. Has 3" suspension lift front eibach springs OME 890 in rear with bilstein 5100's all around with diff drop kit (suspension has about 25k miles on it). I replaced upper and lower ball joints cam adjusters LCA bushings and both CV axles around 190,000 all with Toyota parts. I also replaced the sway bar mounts and steering rack bushings. Truck also has rear locker and remote starter. Here is the bad...frame is rusting.. nothing that a good welder can't fix though. I welded one side of the frame in the rear a few years back where the rear control arm connects (see pics). That part is stronger than new now. Now one of the rear shock mounts needs welding as it has broken off( see pics). One of the front sway bar links is broken, the drivers side leather seat is torn and the CD player does not work. Recently truck has started to idle rough but seems to clear up when warmed up. Has had a CEL for PO301 cyl 3misfire. I will try to investigate if I have time. I have 4 matching tires 2 are not on truck does have spare. Truck needs an alignment because the shop I brought it to could not get it right. Has clear title. Fair condition overall $1200.
erinobr2000
