FS: 3rd gen 4runner front ToyTec lift spacers
99SC4Runner
The spacers are the TAC25 2.5" spacers that sit on top of the front coils.
I no longer need them since I installed Tundra TRD coils in the front of my 4Runner.
They are in great shape and need a new home.
They are normally $119.99 but you can have them for $60 shipped.
Add the top plate spacer kit TOP1-T from ToyTec and you have a 3" lift.
Thanks.<!-- google_ad_section_end --> <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig --><!-- sig -->
Pics of the spacers.... $60 shipped.
I washed them since I took them off my 4Runner, but they could be polished up or run them as is.
Let me know.
Thanks.
No I don't. I reused them on my tundra coils, otherwise I'd sell them for a more money if it included the top plates and bolts.
The spacers are fine as is for 2.5" of lift. The top 1/4" spacers are only to get that extra 1/2" of lift.
I decided to rip the tile out and do something else, so I didn't bother grouting it.
The longer bolts are only for adding top plate spacers. You have to remove the stock bolts and then use longer bolts with the factory top plate and the top plate spacers.
So as these are, you just reuse your factory bolts and top plate. You have to compress the spring and add these spacers to the top of your spring and then put the top plate and rubber gasket parts back on top of that and bolt it all together again.
NVBASSJUNKIE
