Fs: 99 4runner manual, lifted in Pa
98runnerelock
Have a 99 4runner for sale. Has 415,000 on chassis and 180,000 on engine. Had a 98 that the frame rotted on and bought this 99 with a bad engine. Swapped my old engine into the 99 along with a 5-speed swap with new oem clutch and flywheel. Also with oem flywheel bolts. This is no hack job swap. Everything done right down to the interior trim, all sensors working, and no check engine light. Has tan interior with mint condition leather seats. All floor mats and rear cargo cover. Sunroof and rear window work perfectly. Frame is in amazing shape with little knicks of surface rust here and there. Body is also in really good shape, no clear coat failing or paint fade. There is however some paint bubbling around the windshield. Depending on how quick this sells I may have that professionally fixed and price will then reflect that. Also rear bumper could use replacing. The truck has a all-pro off-road 3 inch lift and Oem O.Z racing wheels that where dealer option on tacomas in the early 2000,s. Will also come with a rear Trd exhaust that is now v-band flange. The muffler had cracked in quite a few places so just the rear end part will come with. Also will send with it a rear elocker axle and housing with wiring harness and computer module. Overall this is one of the cleanest runners I’ve been around. All vins match around the vehicle. Clean title in my name. If you have any questions you can contact me at 717-434-4350. Located in York, Pa.
