Fs denver co cleanest 1st gen 4runner around
CGK
1985 4-runner FULLY built
- completely tore down
- rear tube quarters fabricated into the body
- front cab corners removed and flat plated to prevent "tire rubbing/chunking"
- all seam sealed professionally
- custom BMW silver paint- base coat/clear coat (PPG)
- 2 tone paint (black roof)
- 100% custom factory SR5 decals with Toyota logo incorporated into them.
- NEW Soft-topper with tinted windows
- WHOLE interior is rattle trap sound deadening (fat-mat) double layers under front cab section.
- brand new carpet on all passenger areas with jute padding and new backing.
- power windows installed with mint SR5 door panels
- Full Addicted off-road interior roll cage
- new windshield
- all seats in mint condition
- Tacoma complete steering column with tilt (working cruse control)
- 75k MILES 2000 Tacoma 3.4 with the A340F automatic transmission adapted to duel transfer-case with 23 spline input shaft -trail-gear adapter-
- duel case low profile skid crossmember
- COMPLETE UNCUT Tacoma harness was used in the swap!! Bumper TO bumper. This is the cleanest Swap you will ever see. Used Everything out of the Tacoma under the hood. Charcoal canister, cruise control, battery trey, ECT. It's a must see
- Tacoma gauge cluster and heater controls were used (clean install) with LED bulbs
- Addicted off-road complete High pressure powersteering pump kit with resovour, pump, cooler, hydraulic ram on steering, rebuilt steering box tapped for ram assist.
- new fuel pump in tank with ford bracket and filter mounted on frame.
- 2000 tacoma floor shift assembly with console (clean install)
- firewall insulated with heat 2000 degree shield
- custom exhaust with flow-master muffler
- factory low mileage Tacoma catalytic converter with new oxygen sensors
- rear Tacoma Axle housing with E-locker -5.29 gears
- front 85 housing with Chromo inner and outer shafts, E-locker with 5.29 gears, IFS hubs, new bearings and seals, V6 brake calipers, Fj-80 rotors, All-pro high steer, arp knuckle studs
- new Raceline wheels 17x9 with new 37" Cooper STT tires all less than 1500 miles
- rear all-pro 3.5 lift leaf springs
- front all-pro/toyota rear Hybrid leaf spring pack (Rides and flexes amazing
- Addicted off-road rock sliders
- Addicted off-road front and rear bumpers (reinforced front frame for winch)
- new never used XRC-8 winch (all wired in)
- LED front turn signals
- new v6 3.0 radiator with 3.0 mechanical cooling fan
- new dealer 3.0 fan shroud
- new timing belt, water pump, all pulleys, and belts
- Mobil one oil
- new interstate battery
- E-lockers all wired in with Low-range switches on separate fuse box
- Tacoma factory air box
- automatic transmission aux cooler
- Tacoma brake booster/master cylinder
- 88 4runner automatic trans pedal assembly
- all-pro front long spline drive shaft with 85 double CV recent rebuild and balance
- rear shaft is a front 85 double cv shaft rebuilt and balanced
Things that need to be done that I will do soon before it gets sold
- slight axle seal leak LF
- heater bad in upstream oxygen sensor
- installing new radio
- repaint rock sliders.
- air conditioning lines need made - A/C will be 100% functional
Asking $16250.00. Only thing I will trade for is a 05-up 4door Tacoma
Its an awesome truck I'm so happy with it! This rig replaced my 3rd gen and i will start a build continuations thread here soon!
DO NOT GET RID OF THIS THING!!! YOU WILL REGRET IT!!
that is the most beautiful thing I've ever seen. But for real why? This should be a family heirloom.
Oh Nvm just saw it was already sold. :(
Cpn2mss
