FS: Like New ARB Twin Compressor + Manifold + Custom Harness (Bay Area, CA) - $SOLD
cutty01
*** SOLD ***
This is ARB's most power compressor! It was originally designed for military use and now available for consumers. Almost everything you need to air up your tires, run air lockers, or run air tools (1 gallon+ tank recommended for running air tools).
Includes:
  • Barely Used ARB Twin Compressor CKMTA12
  • Brand New Main Supply Wire Harness 180414
  • Brand New Switch Harness 180415
  • Brand New Custom Switch Harness (for direct connection to you switched power distribution fuse box)
  • Barely Used Manifold Kit 171503
  • Compressor Mounting Bolts
  • Manifold Mounting Bolts
  • Installed Ring Terminals on Power Leads
Priced very fair for a fellow forum member. $475 is only a few dollars more than the last group buy which was for the compressor only. This sale includes a manifold kit, custom wire harness, and ring terminals. If you were to buy all these new you would spend $604:
- Twin Compressor - $517.99
- Manifold Kit - 67.99
- Custom Harness - $14.99
- Ring terminals - 2.99
Notes:
- The custom harness is good if you only are using the compressor to air up your tires. It eliminates the ARB switch harnesses which has extra wires for the locker solenoids and multiple switches.
- The ring terminals for the two positive leads were purposely installed upside down so you can tuck the in-line 40Amp fuses, otherwise they would stick out.
- The only thing missing from the out of the box kit is the ARB switch, but most of us use our own switches.
- Online installation manual found HERE.
I bought the compressor and manifold kit from another forum member but I have decided not to use it. I tested the compressor to confirm it worked. The prior owner had cut up the wire harnesses so I bought all wire harnesses new.
Compressor is in near perfect cosmetic condition. The manifold has some scuff marks on one side.
Local pick up or add $25 for shipping to Cont US (sorry the compressor alone is 20lbs and shipping prices are nutz these days).
pax at 4
