FS. Parting 2000 4Runner Limited Auto 4WD Troutdale OR
Junction box needed
Hi. I need the 5-way junction box for towing. The box I'm referring to is located in front of the driver's side tail light behind the interior trunk panel. It connects to the body via a ground wire that's held on by a 10mm bolt and has two harnessed that connect to it. I need the box and the trailer harness that's attached to the hitch. I don't need the main harness that goes into the body. Hope you can help me. Thanks!
A+ for great seller. Thanks man.
Is the valence panel plate intact (not sure if that's the correct name for the part)? ...It's the small rectangular plastic plate thats on the lower valence...it's loosely hanging on the front end in the pic you posted.
Price for a couple of these parts in the pic below? It is pointing to the little plastic piece at the base of the door locks.
UMQVw6m8jcwHuYKF9
If the above doesn't work, here is the URL
https://goo.gl/photos/95Z9wZtq7qGYZYZu5
Also, how much for the radio?
04250
Do you have:
Left and right rear view mirror assemblies
Rear view mirror assembly
License plate surround
Drivers seat belt
57702
Thank you
Giordano Schoenwetter
