FS: Rowe Electronics PDM60 - $165 Long Beach, Ca
vvtisupra
1) Rowe Electronics - PDM 60 - automotive version (has an ignition buffer that protects the PDM60 from the starter drain when going from ignition to actual starting the vehicle.
2) NEW IN PACKAGE + USB Program Cable
3) $165 Shipped +3% paypal fee each.
4) Long Beach, Ca.
5) At least one picture of the item for sale or for trade
Hi Guys,
Have two extra Rowe PDM 60 (PDM60 PDM60 - Rowe Electronics)
I planned on wiring one for the front of my car and one for the rear of my car, but decided on running less lights in the rear so I can run 1 wire to the light bar in the rear.
What is cool about this product.
NO Fuses to replace
Fully Programable AMP output & ground or ignition trigger
60 AMP Combined Max
No Messy Wiring
I have this little gem powering a USB charging station with 4 outputs at 2 amps each port, my CB radio and my 36" light bar. This Box acts as a fuse block, with fully configurable amp outputs up to 15 amp max per wire. In cases where more amps are needed I just ran 2 wires at 15 amps (30 amp total) powering my light bar. It has an LED panel display that will tell you which output triggered a disconnection. To reset it just power off the PDM60 and power it back on and it is reset, no need to replace fuses.
I also have the Light bar on a ground trigger (method selection for power output from the pdm60). The trigger i simply wired it to a toggle switch that connects ground to the chassis and sits in my existing empty spots for a push button.
044runner4
