FS: SOLD - 01 4Runner - AT, 4WD, ARB Bumper, Winch, Lift, NO RUST - NY - SOLD
Tim P
2001 4Runner SR5 - Automatic, 4WD
-235,5xx miles
-Clean CarFax (I have a PDF copy of this I can send to interested parties)
-Passed NYS safety & emissions 8/29/2019
-Truck is located in Upstate NY but has NEVER seen an inch of snow/salt, bought the truck from VA where it spent the last 13 years before I acquired it
-Everything works - AC, all windows, etc.
-Reason for sale is that I'm going to begin using my 5th gen 4Runner for trail duty and don't need two trucks that serve the same purpose.
Photos
Full album here!: 2001 Toyota 4Runner - Google Photos
Asking $5950 OBO - no trades - shipping of the vehicle can be arranged for a serious buyer if desired at additional expense
Maintenance performed in the last 2 years:
(I have kept a folder of all the receipts for these items)
-Full timing belt & water pump service, all associated gaskets etc.
-Alternator
-Fan clutch
-Alignment (after lift and SPC UCAs)
-Idler pulley bearing
-Transmission fluid, filter & pan gasket
-Front swaybar endlinks & brakets
-Transmission mounts
-Valve cover, intake manifold and TB gaskets
-Spark plugs
-Fuel and air filters
-Blower motor resistor
-Driveshaft u-joint and balance
-Front and rear differential fluid
-Transfer case fluid
Known Issues
-AC compressor clutch bearing is noisy (has been this way for last 5500 miles with no actual functional issue)
-Exhaust tailpipe fell off (exhaust system ends at the muffler now)
-Truck should have an extended brake line installed at the rear diff location for peace of mind
-Radio antenna was removed and not replaced
Modifications
Suspension, wheels & tires
-Mastercraft Courser MXTs - less than 5k miles of use - on factory 5 star wheels (incl. matching full size spare tire and wheel)
-SPC UCAs
-3in ToyTec lift - Front 5100s with Eibach springs and Rear Toytec shocks with Superflex rear coils
-Panhard correction brackets
-Power steering rack bushing upgrade
-1.5in wheel spacers
Armor
-ARB front bull bar bumper with Superwinch TS9500SR - winch has zero pulls on it, brand new, tested but never used for recovery
-Custom weld-on sliders made from .120 wall DOM
Lighting
-Xenon Depot bi-xenon projectors retrofit and Morimoto 55w HID kit
-Ditch light brackets and LED ditch lights
Misc
-Transmission fluid cooler
-Rear diff breather
-Front diff drop
-7 pin trailer connector
-Upgraded head unit
Thanks for looking!
How'd you like the Toytec lift??
I definitely like the setup. Basic but very functional, budget friendly but also a good value. The front was a bit stiff without the weight of the ARB bumper and winch combo, but once those were installed it improved the ride in the front end tenfold. The rear was phenomenal since day 1; tons of traction-finding flex. I definitely recommend the product if it fits your needs.
Hello, if you would please send me a message with your email so I can ask you a few questions?
Thank you,
Paul
Bump! The truck just passed NYS safety & emissions inspection today! Would really like to find a new home for it - shoot me offers!
pax at 4
