I decided to replace the fuel filter, following these simple instructions:
5VZ V6 4runner fuel filter write up with pics | IH8MUD Forum
Got the old one off, put the new one on, and started it - had a leak from the front of the filter. I put the old one back on, and tightened it to the same tightness... it calls for 18ft/lbs so I did it a bit past snug. Essentially until the threads hit. With the old one back on, there were no leaks. Took the replacement fuel filter back to Toyota and exchanged it for another one.
Now, after I install this second replacement filter, it leaks out of BOTH sides. I carefully took everything back off, and physically held the fuel lines against the filter while I tightened it back up...and it still leaks.
Am I doing something wrong? I don't want to overtighten this thing, but I'm guessing it might need a good bit of torque to get it to where it doesn't leak. The last thing I want to do is break the fitting on the fuel lines themselves. I'm just baffled that the old one would have NO leaks and the new one would leak like crazy!
Before I ask this, I'm already assuming that teflon tape is a big no-no? No type of o-ring or gasket came off of the old ones, so I'm assuming that's not the issue. Please help! I'm at my wit's end.
