Fuel Injectors service with before and after results
justgio928
I have an 88 and 87 4runner. The 87 SR5 hasn't ran well since I bought it (package deal) and with a heavy knock so after a lot of different tests I decided to have the fuel injectors cleaned and flow matched.
I used cruzinperformance and they did a great job.
My reason for posting is I want some opinions on if the results shown (specifically before) could have been causing the bog and knock the 87's been having. Any thoughts?
if those numbers are true. its a possibility since it does look like it had poor spray pattern and number 4 had low flow.
even after looking at the numbers. the real test is. how does it run now
I don't have the injectors back yet so I'll let you know once I get them back in.
And the total with $100 insurance and usps priority mail shiiped back to me was $77.50. Not bad at all.
I had Rich @ Cruzin Performance clean and test the injectors on my 3.0 over the summer. If I recall, it was just over $100 shipped, service was quick and the injectors turned out great. Once I got the 3.0 back together and dialed in, it purred like a kitten. Highly recommended
Well I got the injectors back in about a week ago. It ran better but still is having the same issues as before. In a previous post I talked about how adding oil to the cylinder when doing a compression test was able to boost the results so I think that the valves are okay. Could this be a result of the head gasket going bad between two cylinders?
pax at 4
