Fuel range
I get what you're saying, but, my fuel economy was the same even with my 245/75R16
I'm getting 225ish on both my current 4runners and all my 3rd gens from the past.
I wonder how much altitude comes into play...
so are you accounting for the tire size difference or not, it would mean 250 miles instead of 225 per tank. also how much do you put in to fill up?
18.5 total. Most gauges wills how empty after 14 gal used. Most I have ever fit in my truck is 15gal. Thats how off our fuel gauge can be.
I have also hit near 300 when Im mainly on the highway. No way I could get 300 in the city.
I know it's been talked about before, but man...the difference between hwy and city in our trucks is astounding. I went from a 14 mile a day RT commute in all city driving, and a 60 mile a day RT commute nearly all hwy, and I didn't notice nearly as much as I thought I would.
I get 250 on the highway before my gas light comes on, that is pretty much the best mileage I have gotten on the Runner. In the city it's about 195 before gas light comes on. Running BFG KO 265/75/16, 2 inch lift. I think there are to many factors to getting the correct MPG. One big factor is the quality of gas, I am almost sure that not only are you not getting the amount you pay for, but the quality is also degraded. Correct me if I am wrong.
That's interesting, because I see no difference in city and highway. I generally get between 18 and 20mpg and I couldn't tell you why the difference, sometimes I'll get better mpg in the city than on the highway, and sometimes not.
My gas light will come on, I'll go to fill up, it never takes more that 12 gallons. Ever. My gas mileage is all over the place....I think 4Runners get PMS.
Does 91 gas get better mileage and/or better performance in our 3rg gen?
Nope, there is no difference in 85/87/91...ext for gas mileage.
all that number means is the higher ones can handle more pressure without randomly igniting without a spark. I norm use 85 when im above 4k feet.
if you hear pinging(premature ignition) then you need to bump up the higher octane. adding a supercharger with its higher pressure causes you to bump up the octane rating.
So long post for saying octane lvls has no effect one gas mileage :zoom:
Nope....just our wallet. :crybaby:
2000 SR5 5spd SC 430 gears 81000mi 265/75/16,s ...for now.
I drive 50 miles a day highway and run @ 65mph. I get 19mpg now with the SC
Before it was 1 sometimes 2 more.
Drive faster, MPG goes down more....slower.... it might go up but you'll get run over around here.
Just drove to a funeral. 90 miles each way all highway. Kept it at 65 the whole time. I am at half a tank right now, 180 miles. I am hoping it touched the 23 mpg mark.
Same here. My feeling is that the terrible aerodynamics at highway speeds balances out with the stop and go nature of city driving.
I was getting 18 city and about 22 hwy with stock tires, but now that I've got 33s I'm getting 15-16 city and probably 19-20 hwy. But being 2WD and have 3.73s I'm losing mileage because the truck has to work harder to move itself now. Once I swap in a 4.10 or 4.30 locker I think it will be good.
Dang, only 20.3 mpg. I would had through more. I am guessing I was against the wind the entire trip home the way it was blowing me into the other lane.
I find it strange that so many seem to think they have a less than 15 gallon tank.
Mine positively is 18.5 Gallons.
When my light comes on I usually put in between 16-16.5 gallons and my Ultragauge shows 2 gallons left in tank.
If I fill up right when the light comes on, I put less than 15 gallons in my tank. I know that it's 18.5, but the light comes on way early.
Its because there fuel gauge is off. On full empty, running for about an additional 20+ miles and gas light on I have yet to this day fit more than 15 gallons. Two of my buddys with same vehicle have exact issue.
I got 220 miles and 14.2 gallons on last tank and thats driving it for a long time uncomfortably under E trying to find my missing fuel. LOL.
That would suck, hate that running outa gas feeling.
I think I would get a scangauge or ultrragauge if I were you, after a couple tanks of gas it should be calibrated enough for you to fully trust it.
Im cool with 220-250 miles a tank. Also keeps fuel in tank to "to keep the pump cool" LOL.
I dont feel the need of a scanguage on this rig. No boost, nitrous, SC on this thing.
