Fuel Tank Relocation (and new Rear Bumper design)
Tank is in! No leaks and everything works including the gauge. Can totally tell the difference in weight driving with a full tank. I was worried that the gauge wasn't working even though I pumped the 1/4 of a tank I had left from the stock tank. I guess my original sender wasn't reading correctly. It took 16 gallons on fill up. There is now a cavernous space for a air compressor and air tank! Whoot. On to pics. Filler neck is 2" used 2 90* hoses and 1 coupler. Cut the filler neck and vent tube when the bend starts on the neck where it goes under the body.
Edit - don't know why some of the pics are upside down.
Last pic. Use a oem connector for the sender. Once I get my electrical up to snuff then I'll remove the fuse and ground I have for the pump. Car fired right up after it primed the lines. [MENTION=28464]eimkeith[/MENTION] everything went together perfectly, the bumper, tank mounts all tie in together awesomely.
Yes it's a lot of work but it's so worth it. So much room under there now. Just need to make a skid plate for the tank. Just wonder what thickness I should use 1/8, 3/16 or 1/4 plate.
I’m going with 3/16 for the skid plate I’m gonna make. I got my truck driving around now. I’m considering getting the Oem pump grafted into the tank but maybe next winter. I just wanna drive my truck haha. Yours looks great!!! Tbh the autometer gauge doesn’t look awful
Thank you! Yes grafting the oem stuff was more difficult then I wanted it to be. But it was worth it. As it has the toyota reliability and fuel level works. Yep it's easier going with a autometer gauge I just didn't want an external gauge.
Yes 3/16th sounds like the happy medium.
Alrighty guys I forgot to ask, well with the addition of the rear bumper and fuel tank I'm sitting hard on the helper bumpers (the bumper thing inside the spring). I don't have the coin for a lift so I need suggestions for some rear springs. Right now I have the spare tire, 113 pound rear bumper and now a 19 gallon tank, so tons of weight added to the rear.
I was looking at the ome 890 or 891 springs since I'm guessing with a full tank, spare and the bumper I'm around 200-220 pounds in the rear with no extra gear. I just need to get by untill I can save some cash for a proper lift. Any suggestions, I scoureged the junk yard for LC coils but no dice.
Figure out a kit that can use the toyota stuff and sell it. I bet you'd make a good chunk of cash that way. Might be tough to figure out the custom bracketry and such but you'd have a lot of buyers lined up.
Ask and ye shall receive! See next post for details...
This is what I've been working on for the past couple of weeks.
It is a custom bracket that will mount the 99+ Toyota sending unit onto the F150 fuel pump at the F150 sending unit location. I just finished the design and I am in the process of getting quotes to laser-cut and bend out a set of 25 brackets now.
My intention is to sell this bracket in a kit, the kit will also include a wiring harness, bulkhead connectors, and a detailed set of instructions. I will do my best to make this as plug-and-play as possible.
I'll make an new thread when I am ready to start selling these, I will collect a list of those interested then. In the meantime, let me know what you all think!
uhhh this is fricken awesome. wanted to use real swear words but I know kids are present.
I'm in! Will it require bending the arm/using a new arm?
That bracket looks good. But I do have to say that is one complicated bend in the lever arm. Its actually pretty hard to bend that lever. But that is awesome!
Is the Toyota sender based off the new TSB part (# 83320–35590) or the original, just trying to clear this up for future people.
Edit - looking at [MENTION=177008]Team_Jake[/MENTION] pics and looking at both versions of senders, it looks like it is based off the new tsb 83320-35590 part #. New part # on top, old style on bottom.
Unfortunately with the way the arm presses onto the potentiometer, it will be too difficult to take the old arm off and install a new arm. The arm will need to be bent while it is still attached to the sending unit and the float will have to be re-positioned. I will be making a detailed set of instructions on the steps to do so (or for anyone that will be ordering a new sending unit anyways, I could modify a new sending unit ready-to-go included in the kit).
The sending unit is Toyota part number 83320-35590. I'm not exactly sure when Toyota changed to this particular sending unit (it appears it was sometime in 2000, but I'm not sure), so those of you with model years 1999 or 2000 may not be able to use their stock sending unit (unless you got yours replaced as part of TSB EL010–00). I want to say anyone with a model year 2001+ will be able to use their stock sending unit but I can't confirm that.
Just updating, everything is working fine with the exception of the filler neck hose's. They have gotten soft and have a faint smell of gas. I spoke with the place I bought them from (filler neck supply co) and they said it's nothing to worry about (Bull malarkey), so found some 90 degree metal 1 3/8" bends and some gates straight hose I'll make couplers out of. Why couldn't toyota use 2" filler hose like the rest of the world?
Gauge works great. I pulled apart my old tank and low and behold it had the old style fuel sender in there even though my vin # was in that TSB and the TSB was done on my truck.
So if you plan on running [MENTION=177008]Team_Jake[/MENTION] bracket, either buy the new sender or verify you have the new updated one pn 83320–35590.
[MENTION=28464]eimkeith[/MENTION] Do you by chance have the bolt hole spacing on the rear bumper/tank mount (the 4 small bolts)? Doing my tank skid tomorrow and this would make it easier for me lol thanks. V12 on the bumper, how much has changed since the first batch just wondering?
Also a update - tank and everything is doing fine. Seems to fill up much better then the stock tank. I also get much more mileage per tank for some reason.
Picked up the metal today for the skid, going with 3/16" plate. Basically going to go a inch or two further then the "sump" in the ford tank (that dimple thing in the middle of the tank). I know rocks and junk probably wont go that far up, but if a car rear ends me it sure will make it quite far lol. Should be fun, that plate is quite heavy. Also I went with LC 80 kyb shocks and OME 891 springs and it rides like butter with all the weight in the back!
[MENTION=28464]eimkeith[/MENTION] V12 on the bumper, how much has changed since the first batch just wondering?
Quite a bit, internally; the square tube is now gone:
<blockquote class="instagram-media" data-instgrm-captioned data-instgrm-permalink="https://www.instagram.com/p/CB3eOEdHqp4/?utm_source=ig_embed&utm_campaign=loading" data-instgrm-version="12" style=" background:#FFF; border:0; border-radius:3px; box-shadow:0 0 1px 0 rgba(0,0,0,0.5),0 1px 10px 0 rgba(0,0,0,0.15); margin: 1px; max-width:540px; min-width:326px; padding:0; width:99.375%; width:-webkit-calc(100% - 2px); width:calc(100% - 2px);"><div style="padding:16px;"> <a href="https://www.instagram.com/p/CB3eOEdHqp4/?utm_source=ig_embed&utm_campaign=loading" style=" background:#FFFFFF; line-height:0; padding:0 0; text-align:center; text-decoration:none; width:100%;" target="_blank"> <div style=" display: flex; flex-direction: row; align-items: center;"> <div style="background-color: #F4F4F4; border-radius: 50%; flex-grow: 0; height: 40px; margin-right: 14px; width: 40px;"></div> <div style="display: flex; flex-direction: column; flex-grow: 1; justify-content: center;"> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; margin-bottom: 6px; width: 100px;"></div> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; width: 60px;"></div></div></div><div style="padding: 19% 0;"></div> <div style="display:block; height:50px; margin:0 auto 12px; width:50px;"><svg width="50px" height="50px" viewBox="0 0 60 60" version="1.1" xmlns="https://www.w3.org/2000/svg" xmlns:xlink="https://www.w3.org/1999/xlink"><g stroke="none" stroke-width="1" fill="none" fill-rule="evenodd"><g transform="translate(-511.000000, -20.000000)" fill="#000000"><g><path d="M556.869,30.41 C554.814,30.41 553.148,32.076 553.148,34.131 C553.148,36.186 554.814,37.852 556.869,37.852 C558.924,37.852 560.59,36.186 560.59,34.131 C560.59,32.076 558.924,30.41 556.869,30.41 M541,60.657 C535.114,60.657 530.342,55.887 530.342,50 C530.342,44.114 535.114,39.342 541,39.342 C546.887,39.342 551.658,44.114 551.658,50 C551.658,55.887 546.887,60.657 541,60.657 M541,33.886 C532.1,33.886 524.886,41.1 524.886,50 C524.886,58.899 532.1,66.113 541,66.113 C549.9,66.113 557.115,58.899 557.115,50 C557.115,41.1 549.9,33.886 541,33.886 M565.378,62.101 C565.244,65.022 564.756,66.606 564.346,67.663 C563.803,69.06 563.154,70.057 562.106,71.106 C561.058,72.155 560.06,72.803 558.662,73.347 C557.607,73.757 556.021,74.244 553.102,74.378 C549.944,74.521 548.997,74.552 541,74.552 C533.003,74.552 532.056,74.521 528.898,74.378 C525.979,74.244 524.393,73.757 523.338,73.347 C521.94,72.803 520.942,72.155 519.894,71.106 C518.846,70.057 518.197,69.06 517.654,67.663 C517.244,66.606 516.755,65.022 516.623,62.101 C516.479,58.943 516.448,57.996 516.448,50 C516.448,42.003 516.479,41.056 516.623,37.899 C516.755,34.978 517.244,33.391 517.654,32.338 C518.197,30.938 518.846,29.942 519.894,28.894 C520.942,27.846 521.94,27.196 523.338,26.654 C524.393,26.244 525.979,25.756 528.898,25.623 C532.057,25.479 533.004,25.448 541,25.448 C548.997,25.448 549.943,25.479 553.102,25.623 C556.021,25.756 557.607,26.244 558.662,26.654 C560.06,27.196 561.058,27.846 562.106,28.894 C563.154,29.942 563.803,30.938 564.346,32.338 C564.756,33.391 565.244,34.978 565.378,37.899 C565.522,41.056 565.552,42.003 565.552,50 C565.552,57.996 565.522,58.943 565.378,62.101 M570.82,37.631 C570.674,34.438 570.167,32.258 569.425,30.349 C568.659,28.377 567.633,26.702 565.965,25.035 C564.297,23.368 562.623,22.342 560.652,21.575 C558.743,20.834 556.562,20.326 553.369,20.18 C550.169,20.033 549.148,20 541,20 C532.853,20 531.831,20.033 528.631,20.18 C525.438,20.326 523.257,20.834 521.349,21.575 C519.376,22.342 517.703,23.368 516.035,25.035 C514.368,26.702 513.342,28.377 512.574,30.349 C511.834,32.258 511.326,34.438 511.181,37.631 C511.035,40.831 511,41.851 511,50 C511,58.147 511.035,59.17 511.181,62.369 C511.326,65.562 511.834,67.743 512.574,69.651 C513.342,71.625 514.368,73.296 516.035,74.965 C517.703,76.634 519.376,77.658 521.349,78.425 C523.257,79.167 525.438,79.673 528.631,79.82 C531.831,79.965 532.853,80.001 541,80.001 C549.148,80.001 550.169,79.965 553.369,79.82 C556.562,79.673 558.743,79.167 560.652,78.425 C562.623,77.658 564.297,76.634 565.965,74.965 C567.633,73.296 568.659,71.625 569.425,69.651 C570.167,67.743 570.674,65.562 570.82,62.369 C570.966,59.17 571,58.147 571,50 C571,41.851 570.966,40.831 570.82,37.631"></path></g></g></g></svg></div><div style="padding-top: 8px;"> <div style=" color:#3897f0; font-family:Arial,sans-serif; font-size:14px; font-style:normal; font-weight:550; line-height:18px;"> View this post on Instagram</div></div><div style="padding: 12.5% 0;"></div> <div style="display: flex; flex-direction: row; margin-bottom: 14px; align-items: center;"><div> <div style="background-color: #F4F4F4; border-radius: 50%; height: 12.5px; width: 12.5px; transform: translateX(0px) translateY(7px);"></div> <div style="background-color: #F4F4F4; height: 12.5px; transform: rotate(-45deg) translateX(3px) translateY(1px); width: 12.5px; flex-grow: 0; margin-right: 14px; margin-left: 2px;"></div> <div style="background-color: #F4F4F4; border-radius: 50%; height: 12.5px; width: 12.5px; transform: translateX(9px) translateY(-18px);"></div></div><div style="margin-left: 8px;"> <div style=" background-color: #F4F4F4; border-radius: 50%; flex-grow: 0; height: 20px; width: 20px;"></div> <div style=" width: 0; height: 0; border-top: 2px solid transparent; border-left: 6px solid #f4f4f4; border-bottom: 2px solid transparent; transform: translateX(16px) translateY(-4px) rotate(30deg)"></div></div><div style="margin-left: auto;"> <div style=" width: 0px; border-top: 8px solid #F4F4F4; border-right: 8px solid transparent; transform: translateY(16px);"></div> <div style=" background-color: #F4F4F4; flex-grow: 0; height: 12px; width: 16px; transform: translateY(-4px);"></div> <div style=" width: 0; height: 0; border-top: 8px solid #F4F4F4; border-left: 8px solid transparent; transform: translateY(-4px) translateX(8px);"></div></div></div></a> <p style=" margin:8px 0 0 0; padding:0 4px;"> <a href="https://www.instagram.com/p/CB3eOEdHqp4/?utm_source=ig_embed&utm_campaign=loading" style=" color:#000; font-family:Arial,sans-serif; font-size:14px; font-style:normal; font-weight:normal; line-height:17px; text-decoration:none; word-wrap:break-word;" target="_blank">packing up Sam’s bumper; still excited about the new v12 internal structure.</a></p> <p style=" color:#c9c8cd; font-family:Arial,sans-serif; font-size:14px; line-height:17px; margin-bottom:0; margin-top:8px; overflow:hidden; padding:8px 0 7px; text-align:center; text-overflow:ellipsis; white-space:nowrap;">A post shared by <a href="https://www.instagram.com/eimkeith/?utm_source=ig_embed&utm_campaign=loading" style=" color:#c9c8cd; font-family:Arial,sans-serif; font-size:14px; font-style:normal; font-weight:normal; line-height:17px;" target="_blank"> J Keith Walters</a> (@eimkeith) on <time style=" font-family:Arial,sans-serif; font-size:14px; line-height:17px;" datetime="2020-06-25T17:39:09+00:00">Jun 25, 2020 at 10:39am PDT</time></p></div></blockquote> <script async src="//www.instagram.com/embed.js"></script>
<blockquote class="instagram-media" data-instgrm-captioned data-instgrm-permalink="https://www.instagram.com/p/B_qICOHnxXr/?utm_source=ig_embed&utm_campaign=loading" data-instgrm-version="12" style=" background:#FFF; border:0; border-radius:3px; box-shadow:0 0 1px 0 rgba(0,0,0,0.5),0 1px 10px 0 rgba(0,0,0,0.15); margin: 1px; max-width:540px; min-width:326px; padding:0; width:99.375%; width:-webkit-calc(100% - 2px); width:calc(100% - 2px);"><div style="padding:16px;"> <a href="https://www.instagram.com/p/B_qICOHnxXr/?utm_source=ig_embed&utm_campaign=loading" style=" background:#FFFFFF; line-height:0; padding:0 0; text-align:center; text-decoration:none; width:100%;" target="_blank"> <div style=" display: flex; flex-direction: row; align-items: center;"> <div style="background-color: #F4F4F4; border-radius: 50%; flex-grow: 0; height: 40px; margin-right: 14px; width: 40px;"></div> <div style="display: flex; flex-direction: column; flex-grow: 1; justify-content: center;"> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; margin-bottom: 6px; width: 100px;"></div> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; width: 60px;"></div></div></div><div style="padding: 19% 0;"></div> <div style="display:block; height:50px; margin:0 auto 12px; width:50px;"><svg width="50px" height="50px" viewBox="0 0 60 60" version="1.1" xmlns="https://www.w3.org/2000/svg" xmlns:xlink="https://www.w3.org/1999/xlink"><g stroke="none" stroke-width="1" fill="none" fill-rule="evenodd"><g transform="translate(-511.000000, -20.000000)" fill="#000000"><g><path d="M556.869,30.41 C554.814,30.41 553.148,32.076 553.148,34.131 C553.148,36.186 554.814,37.852 556.869,37.852 C558.924,37.852 560.59,36.186 560.59,34.131 C560.59,32.076 558.924,30.41 556.869,30.41 M541,60.657 C535.114,60.657 530.342,55.887 530.342,50 C530.342,44.114 535.114,39.342 541,39.342 C546.887,39.342 551.658,44.114 551.658,50 C551.658,55.887 546.887,60.657 541,60.657 M541,33.886 C532.1,33.886 524.886,41.1 524.886,50 C524.886,58.899 532.1,66.113 541,66.113 C549.9,66.113 557.115,58.899 557.115,50 C557.115,41.1 549.9,33.886 541,33.886 M565.378,62.101 C565.244,65.022 564.756,66.606 564.346,67.663 C563.803,69.06 563.154,70.057 562.106,71.106 C561.058,72.155 560.06,72.803 558.662,73.347 C557.607,73.757 556.021,74.244 553.102,74.378 C549.944,74.521 548.997,74.552 541,74.552 C533.003,74.552 532.056,74.521 528.898,74.378 C525.979,74.244 524.393,73.757 523.338,73.347 C521.94,72.803 520.942,72.155 519.894,71.106 C518.846,70.057 518.197,69.06 517.654,67.663 C517.244,66.606 516.755,65.022 516.623,62.101 C516.479,58.943 516.448,57.996 516.448,50 C516.448,42.003 516.479,41.056 516.623,37.899 C516.755,34.978 517.244,33.391 517.654,32.338 C518.197,30.938 518.846,29.942 519.894,28.894 C520.942,27.846 521.94,27.196 523.338,26.654 C524.393,26.244 525.979,25.756 528.898,25.623 C532.057,25.479 533.004,25.448 541,25.448 C548.997,25.448 549.943,25.479 553.102,25.623 C556.021,25.756 557.607,26.244 558.662,26.654 C560.06,27.196 561.058,27.846 562.106,28.894 C563.154,29.942 563.803,30.938 564.346,32.338 C564.756,33.391 565.244,34.978 565.378,37.899 C565.522,41.056 565.552,42.003 565.552,50 C565.552,57.996 565.522,58.943 565.378,62.101 M570.82,37.631 C570.674,34.438 570.167,32.258 569.425,30.349 C568.659,28.377 567.633,26.702 565.965,25.035 C564.297,23.368 562.623,22.342 560.652,21.575 C558.743,20.834 556.562,20.326 553.369,20.18 C550.169,20.033 549.148,20 541,20 C532.853,20 531.831,20.033 528.631,20.18 C525.438,20.326 523.257,20.834 521.349,21.575 C519.376,22.342 517.703,23.368 516.035,25.035 C514.368,26.702 513.342,28.377 512.574,30.349 C511.834,32.258 511.326,34.438 511.181,37.631 C511.035,40.831 511,41.851 511,50 C511,58.147 511.035,59.17 511.181,62.369 C511.326,65.562 511.834,67.743 512.574,69.651 C513.342,71.625 514.368,73.296 516.035,74.965 C517.703,76.634 519.376,77.658 521.349,78.425 C523.257,79.167 525.438,79.673 528.631,79.82 C531.831,79.965 532.853,80.001 541,80.001 C549.148,80.001 550.169,79.965 553.369,79.82 C556.562,79.673 558.743,79.167 560.652,78.425 C562.623,77.658 564.297,76.634 565.965,74.965 C567.633,73.296 568.659,71.625 569.425,69.651 C570.167,67.743 570.674,65.562 570.82,62.369 C570.966,59.17 571,58.147 571,50 C571,41.851 570.966,40.831 570.82,37.631"></path></g></g></g></svg></div><div style="padding-top: 8px;"> <div style=" color:#3897f0; font-family:Arial,sans-serif; font-size:14px; font-style:normal; font-weight:550; line-height:18px;"> View this post on Instagram</div></div><div style="padding: 12.5% 0;"></div> <div style="display: flex; flex-direction: row; margin-bottom: 14px; align-items: center;"><div> <div style="background-color: #F4F4F4; border-radius: 50%; height: 12.5px; width: 12.5px; transform: translateX(0px) translateY(7px);"></div> <div style="background-color: #F4F4F4; height: 12.5px; transform: rotate(-45deg) translateX(3px) translateY(1px); width: 12.5px; flex-grow: 0; margin-right: 14px; margin-left: 2px;"></div> <div style="background-color: #F4F4F4; border-radius: 50%; height: 12.5px; width: 12.5px; transform: translateX(9px) translateY(-18px);"></div></div><div style="margin-left: 8px;"> <div style=" background-color: #F4F4F4; border-radius: 50%; flex-grow: 0; height: 20px; width: 20px;"></div> <div style=" width: 0; height: 0; border-top: 2px solid transparent; border-left: 6px solid #f4f4f4; border-bottom: 2px solid transparent; transform: translateX(16px) translateY(-4px) rotate(30deg)"></div></div><div style="margin-left: auto;"> <div style=" width: 0px; border-top: 8px solid #F4F4F4; border-right: 8px solid transparent; transform: translateY(16px);"></div> <div style=" background-color: #F4F4F4; flex-grow: 0; height: 12px; width: 16px; transform: translateY(-4px);"></div> <div style=" width: 0; height: 0; border-top: 8px solid #F4F4F4; border-left: 8px solid transparent; transform: translateY(-4px) translateX(8px);"></div></div></div></a> <p style=" margin:8px 0 0 0; padding:0 4px;"> <a href="https://www.instagram.com/p/B_qICOHnxXr/?utm_source=ig_embed&utm_campaign=loading" style=" color:#000; font-family:Arial,sans-serif; font-size:14px; font-style:normal; font-weight:normal; line-height:17px; text-decoration:none; word-wrap:break-word;" target="_blank">3rd gen 4Runner High Clearance Rear Bumper v12 is happening. Every single part has undergone revision (except the nut strips) and now the non-body lift install kits are an actuality. (can be retrofitted to v11 bumpers as well.) PLUS an overkill side impact brace for the bumper wings (if you’re hard in your equipment.) I’ll start taking pre-order deposits this weekend; keep an eye on the website.</a></p> <p style=" color:#c9c8cd; font-family:Arial,sans-serif; font-size:14px; line-height:17px; margin-bottom:0; margin-top:8px; overflow:hidden; padding:8px 0 7px; text-align:center; text-overflow:ellipsis; white-space:nowrap;">A post shared by <a href="https://www.instagram.com/eimkeith/?utm_source=ig_embed&utm_campaign=loading" style=" color:#c9c8cd; font-family:Arial,sans-serif; font-size:14px; font-style:normal; font-weight:normal; line-height:17px;" target="_blank"> J Keith Walters</a> (@eimkeith) on <time style=" font-family:Arial,sans-serif; font-size:14px; line-height:17px;" datetime="2020-05-01T20:12:23+00:00">May 1, 2020 at 1:12pm PDT</time></p></div></blockquote> <script async src="//www.instagram.com/embed.js"></script>
B_qICOHnxXr
and here's a short video explaining that stuff.
[MENTION=28464]eimkeith[/MENTION] that's perfect, just what I was looking for thanks for the measurements! Those look like some awesome improvements! Don't have Instagram so I never see what new lol. Thanks for those posts!
leolediola
