I had to take mine apart to get to the main fuse when i blew it once... was a pain in the A.., once you get the board out it snot so bad but getting it disconnected from the plastic box it is in , is the hard part. If you are replacing it id recommend replacing the main fuse and the other one in case for some reason you blow them, this will save you hassle for when they do because they are bolted in. Good Luck.:thumb:
