Fuse help
MAD 69
Wondering you guys can help me out, I'm on the beach surf fishing and I blew a couple fuses - I have no radio, clock or cig lighter and my phone is dying fast! Not sure if I have heat either but I don't have my owners manual in the truck. Do I have to go under the hood or is it the box under the driver door panel?
'98 T4R by the way...
There is a fuse box in the engine bay right behind the battery.
There is also another one in the driver side under-panel.
It's not an 'either/or' -- they are 2 different boxes and handle different fuses/wiring.
Yes I know where the fuse boxes are just wondering which one I have to check and change, it's not labeled very clear
You posted for this same problem a LONG time ago. :p
There is a 15A fuse labeled ACC in the fuse box in your drivers kick panel.
If it's blown, it will not allow power to the things you have listed.
Edit** To be more clear, the FSM has it listed as the fuse for all of these functions...
Auto Antenna
Cigarette Lighter and Clock
Multiplex Communication System
Power Outlet
Power Window (Rear), Rear Wiper and Washer
Radio and Player
Rear Window Defogger and Mirror Heater
Remote Control Mirror
Shift Lock
Theft Deterrent
Wireless Door Lock Control
Ok thanks, didn't realize I had this problem before, I haven't posted in here in over a year...
Got my heater working again but can't keep the 15a number 20 position fuse from blowing, not sure why it breaks the fuse as soon as I put it in, does anyone have a fix for this? Thanks again
Deno91
