Fusebox
ConstantFix
Does the fuse box have any grounds. Im having such weird elctrical problems and have checked all my other grounds and everything is fine. The enginenruns perfectly fine, but anything else, headlights, turn signals. They are all dim. Radio cuts out if i turn the headlights on. I had to tear into my fusebox to replace the 100a fuse and was wondering if i may have a ground in there...
Ok man.
Here's the best advice I can give you at the moment.
We know it's an electrical issue, right?
Take the fuze box off, along with the wiring, and everything else that you have in there.
Go through every wire, INCH BY INCH, and SOLDER them together. Then shrink wrap. Then tighten each and every nut you can possibly see.
Go through fuzes, relays, the interrior fuze box, located by your left knee.
Take it all apart, clean it, tighten it, reinstall it.
You'll probably find your weak point during that.
I know it's a PITA, but it's your best bet right now....
Ok man.
lol thanks bud. all me and my car have been doing lately is: :uzi::gun4: and im sick of it i guess tommorow ill get up bright and early and start tearing into everything. double and tripple checking everything. our campsites have been getting snow lately and seenings as me and my car are from Canada, we need our fix! so heres to hoping i can get this sorted out tommorow and head up to the mountains this weekend. wish me luck.!!
