garage pic request
bmwmkc323i
Hi all,
Does anyone here have a 2014 and up 4runner and also a 2011 and up Toyota Sienna XLE mini van by any chance? If so, could you post some garage pictures of both of them parked inside?
I have a 2011 Sienna now, and also interested to get a 2014 and up 4runner, but I need to be sure if it can fit in our garage.
Thanks in advance!
the 4runner is honestly not that big, right now we have my 4runner and my wife's 2012 535i. The 5 series is bigger...
OP - keep in mind garage door height and widths vary... as do garage ceiling heights. Do your own measuring.
Garage door clearance
^ What WAT said.
My garage door just cleared my 4Runner even after adding the Baja Racks flat Utility Rack. This rack is not any taller than the OEM roof rack rails, AFAIK. Then I did the 3" lift. Now it scrapes the door tension rod just barely. Measure up from the slab floor at the entry to the door's lowest point. When the front and rear tires rise up on the slab the roof rack has to clear.
Measure twice, cut once. :nod:
Unless the 4R and Sienna owner also has the exact same garage as you... what does the picture accomplish? You have no way of knowing how the two will work in your garage.
If you have to know and measurements aren't good enough, take the 4R on a test drive to your house and park it in there.
DionicioLives
