Gas Tank Size?
4runmak
I have a 2000 SR5 4WD V-6. I have never pump more than about 13 gallons (when the gas light is on) into the tank. I read a different post and noticed that the tank sizes were 18 gal. I looked on the edmounds site
http://www.edmunds.com/used/2000/toyota/4runner/11113/specs.html
and they say it should be a 18.5 gallon tank. I bought this from toyota as certified used and Im wondering if its possible that some 4runners came with a about 13 gallon tank?
I believe all 3rd gens have 18.5 gal tanks. They also come with a very conservative low fuel warning light - I rarely pump more than 15 gallons.
you are not alone
this is a common theme among us 3rd generation owners. The fuel light comes on quite early, there is a Technical Service bulletin regarding the float level and sending unit mounted in the tank.
See other posts in this area, "how many miles on a tank of gas" and the like....
I've never squeezed more than 16.1 into my tank and the guage was below empty.
In most gas tanks there will be a gallon or so of unuseable fuel since fuel pump pickups rarely sit on the very bottom.
We'll thank you all for the info. 1 more question though......
Since I bought this certified used back in '03, dont you think they would've change the parts under that TSB, or do you think toyota said screw it, it works ok but not perfectly and no ones gonna notice.
good point on Certified used
That makes a lot of sense 4runmak-I would double check your paperwork on the purchase and see if they have a checklist on what they did to certify your vehicle. I would guess they have record that the Tech Svc Bulletin repair was completed, I have seen mixed reports on whether or not that solved the problem of the fuel gauge light coming on way too early. If you don't have a checklist then certainly I would think it may be worth your time to explore that with the Sales or Service Manager at the dealership.
Remember that the Previous Owner (PO) may have found out about the TSB and had the work done before selling it back to the dealership, but again that should be in the computer records I would think.
Old thread revival but i was a little shocked at the pump for the first time the other day:
IMG_1018-2.jpg~original
I'd call the city/state and have the gas stations meter checked. I believe its someone who works for the governors office (in ohio) who checks them and stamps the "seal of approval" on them, since it says approved by Ted Strickland.
Because correct me if i'm wrong, the above pic is physically impossible. I doubt there is a half gallon in the tank spout, and even then it would mean you had zero gas. There is usually a gallon of unuseable gas in the third gens also. I smell the gas station ripping people off.
I agree, the pump is probably wrong. I've sputtered into the station once and still didn't even put 17 in the tank.
Good info here, thought I would bump. Went months never putting more than 13 gals in the tank, 2000 Lmtd.
I have actually driven over 100 miles after the low light came on. (with fuel can in back) I can't remember how much gas it took but I do remember thinking that I had another gallon or so.
Of course we all know that the fuel pump, that is mounted inside the tank, is cooled by the gas. Running your tank dry can cause your pump to burn out. Try to keep some gas in the tank.
See, that's why I like this site. I never really considered that, but I bet that could be a big concern in the desert.
I agree with Brian about the site, so full of knowledge. I'm learning new things everyday.
I'm glad when I'm off roading in the desert I have my gas tank that I use for my quad with me. Just in case..
so here's another GAS question . . . can yall hear the gas gurgle on the way down? do you have to wait for the gurgle to quit to pump more gas? i usually TRY to get as much as i can in there (sometimes it overflows). i rarely stop on the first click.....just wondering what everyone else is experiencing
Most of the time I'll put the pump on slow fill and stop at the first click. If I'm on a road trip I'll try to get more in.
You shouldn't fill it up till it comes out because there should be a little room for expansion.
I am with you, when i hear the first click I try to just even out the dollar amount.
Mike Sargent
