gfxcruncher's build/adventures
hey man is there a way I can get in contact with you to get some details about your rear swing out? I am wanting to build this soon and had a few questions I wanted to see if you had info to share
Sure thing! Drop me a pm with a number, we can text/talk blah blah blah....
On Board Water
Been a while, life kinda got I the way... BUT. Finally checked one off that I'd wanted to do for a looong time! Not a super detailed write up, but here's what I wound up making...
9 Gallon tank, three hookups and it's ready. (I hate setting crap up at camp)
<a data-flickr-embed="true" href="https://www.flickr.com/photos/186714437@N07/52355071662/in/dateposted/" title="Untitled"><img src="https://live.staticflickr.com/65535/52355071662_77cd246f30.jpg" width="375" height="500" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Required a little surgery, had to cut out the spare tire crossmember and some of the associated bracket things that were on the rear crossmember... but it's not like I'll ever be using that area for anything since the swing outs are permanent...
Found a 9 gal tank that fit perfectly, not too bad
9 Gallon Rectangle Poly Tank R-RB288 | Plastic-Mart
<a data-flickr-embed="true" href="https://www.flickr.com/photos/186714437@N07/52355071607/in/dateposted/" title="Untitled"><img src="https://live.staticflickr.com/65535/52355071607_d267c350cf.jpg" width="500" height="377" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
tapped the tank (it's pretty thick) and threaded these suckers in. 4 total, vent, fill, drain and pump out
McMaster-Carr
plumbed with 3/8 line
Amazon.com : 3/8’’ ID x 19/32’’ OD - 25 ft Clear Braided Hose Plastic Vinyl Tubing, with 2 Clamps High Pressure Flexible Reinforced PVC Tube for Transfer Water Air Oil, BPA Free & Non-Toxic : Tools & Home Improvement
used 3/8 pressure fittings for the fill and exit (mostly cause they look cleaner sticking out of the bumper) Got rubber end caps to cover, think they're 13mm ID
Amazon.com: Hotop 4 Sets NPT 3/8 Inch Stainless Steel Male and Female Quick Connector Kit Pressure Washer Adapters Hose Quick Connector (External Thread) : Patio, Lawn & Garden
<a data-flickr-embed="true" href="https://www.flickr.com/photos/186714437@N07/52356442005/in/dateposted/" title="Untitled"><img src="https://live.staticflickr.com/65535/52356442005_98b1a2c24f.jpg" width="500" height="377" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Seaflow pump
Amazon.com : Seaflo 12V DC 1.2 GPM 35 PSI 21-Series Diaphragm Water Pressure Pump for Caravan/RV/Boat/Marine : Sports & Outdoors
Mounted the hot water heater in a HF Pelican knockoff and it mounts to the swing out
The tray is made from 2" angle held to the rail with nutserts, flush w bottom of the frame rail, didn't want it getting hung up when coming off something (bumper cover has taken some abuse...
<a data-flickr-embed="true" href="https://www.flickr.com/photos/186714437@N07/52356015816/in/dateposted/" title="Untitled"><img src="https://live.staticflickr.com/65535/52356015816_847f196285.jpg" width="500" height="375" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
hard to get picks, but can see how it fits up in there somewhat...
<a data-flickr-embed="true" href="https://www.flickr.com/photos/186714437@N07/52356259708/in/dateposted/" title="Untitled"><img src="https://live.staticflickr.com/65535/52356259708_fd27c0b0a6.jpg" width="500" height="377" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Ta Da! (video)
<a data-flickr-embed="true" href="https://www.flickr.com/photos/186714437@N07/52356259768/in/dateposted/" title="Untitled"><img src="https://live.staticflickr.com/31337/52356259768_ede3be2bcf.jpg" width="281" height="500" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
freddygino
