Gobi Hi Lift
Doublehaul
I've got the hi lift kit from Gobi that I haven't installed yet. Which model Hi Lift should I get? Anything specific, or will it fit any hi lift jack?
Check Amazon, you should be able to get the standard 48" version for about $70. Imo the 60" is to big.
I have the 60 inch standard and feel that the 48 would have better, the 60 is a little more difficult to carry and store.
Instead of getting the extreme version check this out and see if this would work for you I like it, and it is not much more expensive then adding the extreme option.
JackMate Lift Jack Accessory - Luminous Silver : Amazon.com : Automotive
Or look at the Radflo hydra-jack.
Radflo Suspension Technology Hydra-Jac Hydraulic Jack - 4-Wheel & Off-Road Magazine
Okki
The 48" is perfect for the height I've seen most of these trucks and was perfect for mine 3" lift on 32" A/T's. Never maxed it out.
I had a Hi-Lift brand and loved it
The jack points on the 5th gen sr5 are not obvious. What jack points do you use for changing tires?
I use my Shrockworks slider. as close tot he wheel I'm trying to lift as possible. a hi-Lift will not reach far enough under the body to use the jack points for the bottle jack. the bottle jack points are indicated in the user manual.
I have a video in my build thread on how to lift by your slider using the SBE adapter.
Okki
