Got a PIE TOY03-AUX... some questions before I install.
Wah
Hi, I have some questions. First, I was wondering where (and how) did you guys mounted your PIE aux adaptors? Second, how long of an RCA-3.5mm cable do I need and where should I run it to? I'm gonna be using it to hook up my ipod and hopefully a satellite tuner to my Scion 6-CD HU.
Thanks.
I was just notified that my 03-05 Toy-Aux has been shipped and im expecting it tomorrow. I'm planning on installing a Scion H.U. and my Roady2 XM with it. Does this unit fit behind the dash?? I.E. Is there enough room. Then i have to get up the nerve to remove my dash and do the radio swap. I'll probably have it done as im seriously mechanically challenged!!!!:arrow:
sharp4runr said:
Wah - Is this the newer version of the PIE unit that fixes the intermittent powering off issue? I mounted mine behind the dash unit, it actually sits behind the pocket under the A/C controls.
July
Yeah, brand new... just got it from Logjam today. Did you use double sided tape or anything to keep it in place? Also, are you running a rca to 3.5mm cable from it?
Sharp.......Holy Crap!!!!! Thats still a fairly frightening job to someone like me!!! Great link on the removal/install though from Carlucci. Thanks for forwarding it!!!! Much appreciated.
Guys - Yes I'm running an RCA to 3.5m so I can hook up an external source (for me its a portable dvd player, but I do want to get an ipod) . I just used an RCA cable from the home stereo then I bought an adapter from Radio Shack that converts RCA to the head phone jack. No I didn't use doublesided tape as it is pretty snug back there and I haven't heard any noises that it was moving around.
NY - It looks daunting from the pics, but if you follow the directions exactly you will NOT have any problems. I've since ripped apart the dash numerous times troubleshooting the PIE unit and also when I swapped the single disc JBL to a 6 disc in dash JBL unit.
Check out page 2 of this thread to see where I have mine: http://www.toyota-4runner.org/showt...perpage=15&highlight=pie install&pagenumber=1
Great pics of the PIE as it fits in there nice and snug. I will be receiving the new PIE release tomorrow after an extended wait. I'm gonna have to take a handful of "COURAGE PILLS" before i attempt it though..Thanks for the assist!!!!!:bash:
He is right about it being easy. As long as you have the tools it is a snap. Just take your time and be patient. The first time takes the longest. Since i initially changed out the deck i have probably done it 10 times, now it only takes like 20 minutes to open it up swap a deck or whatever and put it all back together. Good luck.
Hey, you'll love your adapter. I use mine all the time.
I mounted mine below the HVAC controls, just to the right (passenger) side of the storage box below those controls. Once you get your console taken apart, you'll see a space where the PIE will fit really well. It's tight, too, so there's no rattling around. I didn't use any double-sided tape or any other adhesive.
As for a cable, I used a six-foot (it may have been a bit longer) miniplug-to-RCA cable from Monster that went from the adapter just down the center tunnel to the storage tray behind the shifter. I probably could have gotten away with a three-foot cable, but what the hell. Extra cable is just coiled up and kept out of the way in the tunnel.
I was really intimidated at first at the thought of tearing out the dashboard in my truck. But it really is easy. I got the whole job done in less than two hours, following those Castelluci directions.
Good luck!
Unlike Sharp4, I just mounted mine right behind the radio. I guess mounting is a loose term. I just set it upright behind the radio, the wire ribbons will hold it snug back there. You could use double sided tape if you were so inclined.
How long an RCA adapter? Depends on where you are going to mount/rest your IPOD. My PIE is connected to a Sirius Sportster that I have mounted by the cupholder. This only requires about a 3 foot cord...
I am going to install my USASpec ipod interface probably this weekend. I think its a little bigger than the PIE so I don't know where I'm going to put it. Guess I'll figure it out when everything is removed. Kinda intimidating but if I can take apart a laptop I should be able to take apart my dash.
Woohoo! Ipod in my car!!! Just installed the PIE today after work. So psyched!!! Now I gotta go drive around and listen to my tunes... :bigok:
