GUIDE: How to use an aftermarket rear view camera with the stock head unit
geofox784
I already wrote this guide, but it was lost during the hack a few weeks ago. Guess I'll type it again from scratch.
My rear view camera shorted out after washing my car. Only displayed a black screen with occasional static. I was going to replace it with another OEM camera, but they are going for about $500 and used cameras were not much better.
I decided to replace the camera with an aftermarket camera. The biggest problem with this is that the OEM camera uses 6v instead of the much more common 12V. I found some 6v cameras, but they were either very expensive or months away in china.
This guide shows specifically how to replace the camera at the OEM location, but you can also use this to know how to wire in an aftermarket location at a relocated location, such as when you install a swing out bumper.
To do this you will need:
- A 12V backup camera. In theory you can use any 12V backup camera, but I would used this one because it resembles the shape of the OEM cam. (Update: I switched to a better camera. See bottom of this post)
- A DC to DC boost converter.
- A soldering iron
- Shrink tubing
- Hot glue
- Drill
- Wire strippers
- Very small flathead screwdriver.
- Wire loom harness tape or similar.
First, remove the camera. I used this guide. It was fairly easy.
This is the wiring diagram from the FSM. I assumed that CGND = camera ground, CB+ = Camera 6V positive, CV- = camera feed ground, and CV+ = camera feed positive. I assumed correctly.
This is the wiring diagram that I created on how to connect the camera. You are going to use the boost converter to bump the 6V up to the needed 12V. You could also power the camera from another 12V source, but this was much easier.
Here is what you should have once you have the camera removed using the guide:
I used a mixture of a drill and hotknife to modify the OEM camera mount to fit the new camera. I had to slot the holes in a small amount as well as remove some plastic so that the camera sat flush with the mount. Luckily the new camera had close mounting hole dimensions to the old cam.
Here it is after attaching it.
Cut and then strip the cable off of the OEM camera.
Solder the boost converter to the OEM cable using the diagram above as a reference. Do NOT attach the camera yet. Plug the cable back into the car and then move the key to the RUN position. This will provide 6V to the boost converter. Using a small screwdriver, adjust the boost converter until you are seeing roughly 12V on the OUT side. Anything between 12V and 14V should be fine. Once this is done, remove the cable and pull out the key.
Wire and then heat shrink everything up using the diagram I made above. I used some hot glue to waterproof the boost converter.
Plug it in and then test it by starting up the car and putting it in reverse. The camera should be working now.
Wrap everything up in wire loom harness tape or similar.
UdNzncC
Reinstall the camera. I folded the cable over itself and then taped it.
Unless you know exactly what OEM looks like, it looks like an OEM camera.
The camera quality is excellent and seems to be much crisper than the stock camera. Low light quality is also great. It does have parking assist lines that don't line up with the floor, but it doesn't bother me much. If this bothers you there are cameras available that have the option to disable the lines. The only thing I don't like about it is that it seems to not show the view as high as the OEM camera. I can't see the "horizon" on a level surface. Not a big deal though.
I later placed the OEM camera in a vice and opened it, or more accurately described exploded it, to see the inside. The small board inside didn't have any visible water damage, but it is a small board so it would be hard to tell. The steel frame around the board had visible rust though, so I think it is safe to say that the failure mode was water ingress into the camera.
Update: I switched to a better camera that is a true 180°. Every camera I found on amazon that advertises 180° is actually quite a bit less than that. With the true ultra wide camera I can see oncoming traffic when backing out of a parking space. Also, it comes in a 6v version so you will not need a boost converter.
Normal aftermarket camera:
A true fisheye camera (the one I linked):
Man, thats a good write up but a tough way to do it! haha
I added a rear bumper with tire carrier and just bought one of these and ran the rca/power mated camera line back and plugged this right into the back of the head unit.
https://www.amazon.com/PAC-CAM-TY11-Reverse-Camera-Harness/dp/B00KWLA3T0
It keeps everything in tact and can be easily unplugged and reversed.
I'm confused. How did you get the 12V? Also, did you run new cabling all of the way from the camera to the back of the head unit? Seems like a lot of work.
I used a fuse tap on the reverse light fuse, running the cable was easy, just ran it under the door trim then popped out through a grommet in the back jack storage area. Whole thing took me less than a half hour.
Thank you SO MUCH for this post. I recently bought a used 2012 4Runner and the backup camera is "missing"... (Long story, can see it HERE...) and I too have been pricing out OEM and equivalent replacement camera options, dealing with wire "hackery" and trying to sort things out. This looks like an excellent alternative to dropping $300 plus on OEM parts. Cheers to you good sir! I'll post an update once I have things up and running again.
geofox784,
I just found your post recently and wanted to try and upgrade my back up camera too. Your solution sounds very simple. But when I clicked on the DC to DC Boost converter link, it didn't work. I was wondering if you would mind just sending the part number of the boost converter and I can find it that way. Thank you, ws20064r.
geofox784,
XL6009 should work.
Also, I switched to a better camera that is a true 180°. Every camera I found on amazon that advertises 180° is actually quite a bit less than that. With the true ultra wide camera I can see oncoming traffic when backing out of a parking space.
XL6009 should work.
geofox784,
Thank you for the Boost Converter part number and also the better camera that is a true 180.
I was looking at the camera sheet and it seems to also come in a 6v version. So I think if I order the 6v version, I don't have to use a
boost converter. Is this correct?
Thank you,
ws20064r
geofox784,
Thank you,
ws20064r
Well check that out. That was not available when I ordered mine. Yes, it should just be plug and play if you get the 6v version.
RC_Fabrication
