Having trouble with reinstallation of Factory Stereo
impulsebrklyn
Ripped out my aftermarket stereo today. Reinstalled factory everything, I figured it was plug and play since i havent touch the factory wiring or used the headunit much. Hooked it everything back up put everything together and well the radio is not turning on. Anyone got any pointers on what to check. This is what i have planned for tommorow!
1. Try and find the fuse!!! Anyone know which one?
2. Check connections behind headunit
3. Check to make sure power is being supplied through factory harness through harness ground. Anyone know which wires??
4. ????????
Thanks Chris
Check that the antenae plugs are connected properly. I believe the ground is achieved through both antenae connections.
I hope you didn't damage it while it was is "storage" Check for any dents or scrapes for a possible reason for the problem.
There are no dents or scratches has been in my closet wrapped up and hasnt been moved since I took it out of the 4runner. But anything is possible we will see after everything is checked. Worst case Ill bring it in for warranty work say it stopped working and see what they do. Chris
Glad the here it, why did you want to reinstall it in the first place? I'm pretty sure mine will remain in "storage" forever more.
he is selling the 4runner. he probably has plans to use his nicer stereo in the new car.
"Ripped out" just seems like a drastic term like you can't deal with it anymore.
