HaydenATX's '15 TE-The Yeti
I think it looks like a proper build even with the slight rake. You don't want a saggy butt when you are loaded up for a trip. Nice job!
Recovery point question
If you get a minute could you explain what you have going on with your recovery points? It kind of looks like hard mounted shackles?
Thanks, Steve.
Thanks, Steve.
Hey Steve,
Those are actually just D-ring shackles from 4wheelparts that attach to the factory recovery points. About $15 a piece
Spent a little time on the trails at Hidden falls adventure park today.
You only added the saw because of the extra weight correct?
I wanted to keep rake when loaded down. With 1.75" in front and stock rear coils plus little 10mm spacers it sat with no rake at all, almost negative frame rake. Put a couple of dogs and gear in the back and it was sagging.
Gotcha, thanks man I want do my build like yours. Keep the mods coming ..:cheers:
Installed the awesome orange boxx fab custom Molle panel that the homie [MENTION=127657]codyHTX[/MENTION] gave me as a bachelor party gift. This thing is rad!
Had I known you was a Star wars fan I would have done something different in the cut out. Never the less I hope you enjoy them.
Have you hit your shackles on rocks while wheeling? Seems like they would potentially catch on rocks and reduce your approach angle.
I haven't noticed it. They swing so they have some give. [MENTION=127657]codyHTX[/MENTION] bungeed his together to make them lay flat against the skid
