Head Lights
do you mean after a good 30 mins driving at night with lights on, when you stop or turn off the vehicle, there's a little haze inside the headlight lens?
after awhile they go away, right?
No. I mean the plastic is cloudy and appears damaged from the sun. I live in Arizona and maybe the sun is just doing it's job on the plastic lenses.
oh, i think that can be a fix by using wax and wet sand. that's what people normally do. i thought you were talking about fog up inside the lens due to the engine block heat.
This was discussed in a previous thread. In short, there is a thin layer on top of the clear plastic that wears off or breaks down in the sun/heat. Although rare, once it starts it will continue. Use a gentle polish to restore the gloss, and order a pair of laminated headlight covers to protect the rest of the lens.
Try a product available from Meguiar's -- the same people who make car waxes. It is sold at most auto parts stores and has the name "Plast-X" on the front of the bottle.
It will set you back $6 or $7, but is enough to do your both of your headlights at least ten times or more.
I use Plast-x too. It is a good product. I use it with a mothers mini-polishing ball which attaches to a drill.
The protective film is made by Lamin-x.
59.95 for pre-cut film for headlights and fog lights.
http://lamin-x.com/ecommerce/os/cat...Csid=a0b6bf57fc8002c66c8bc945b4efd826&x=0&y=0
