Headlight comparison stock vs others
I went to buy some GE Ultra Vision bulbs and learned that GE has discontinued making bulbs. So I guess we'll have to see if someone takes over or if that option is now over. Just thought it might be worthwhile to toss in this thread.
Something I haven't seen discussed is the issues with having brighter lights in the more reflective spectrum and snow driving. If they don't melt the snow off the lenses - it doesn't matter how good the projector is - it scatters light everywhere. Combined with the extra brightness it makes for some really difficult vision in snow. This isn't just an issue for aftermarket HID or LED bulbs, but that type of headlight in general. If it's a lot brighter than OEM - which many are - snow is likely to be a problem even with great projector housings.
I removed my XD with Phillips setup last week again for about the 3rd time. They're great in the summer if aimed correctly once the bulbs burn in and dim down. I just left them on as my DRLs for a long time and once they got dimmer they were great and not obnoxious for other drivers. But the snow situation was just unusable each winter, so I'd pull em back out. I didn't have the same issue with my RX350 HID headlights or my last IS headlights. The IS had headlight washers. But the RX doesn't. There's probably more to it than just that, but if you're on the fence and live in snow country - HIDs in OEM projectors is not a good combo for winter.
Do folks with full HID retrofits or aftermarket housings with proper HID projectors have the same issues?
Funny, I was just reading the latest stuff on that Tacoma forum thread about bulbs, LEDs, etc, and it appears GE Europe at least became Tungsram.
With the GE Lighting sale closed, Tungsram is ready to take on the world - News - Tungsram
And they have a Nighthawk line on Amazon for sale: Amazon.com: Tungsram H11-55NHX/BP2 Nighthawk Xenon Automotive Bulb, 2-pack: Automotive
I'm curious if those are the same thing as the old GE +130. Might be worth giving a shot. Price is pretty reasonable.
Edit: Looks like they're identical to the GE nighthawk Xenons. But maybe tunsgram has the +130 option too? I'll see what I can find. Edit 2; after looking at the Tungsram catalog it appears the H11 XMU (+130) bulb did not carry over to Tungsram, so it's probably dead. :(
EDIT: oops I meant +120s. Haven't seen the 130s in the states yet. A few folks have bought them overseas via Ebay
Walmart is now carrying the Tungsram +130s. Pretty much same packaging but different label
Tungsram H11 Nighthawk Xenon Halogen Bulb, 2-pack - Walmart.com - Walmart.com
Are you referencing driving while it’s actively snowing or just snow covered areas? Hasn’t snowed this year, but when it does I can try to provide this answer.
Driving while it's snowing. Particularly in the very heavy snowfall periods when it's also kinda warm out. We see that fairly frequently in Utah. Somewhere further north it might be -5* and snowing - the snow won't stick to the headlights. But when it's 28* and snowing heavily - it gets pretty bad pretty fast sometimes between the snow buildup on the lights causing the light to scatter and the brighter and more reflective light from the HIDs.
Got it. We see a fair amount of lake effect snow, so I should be able to get an assessment of this assuming it snows sometime this year unlike last year.
Just noticed that there is a new version of the Morimoto 2Stroke LED - v 3.0.
Morimoto 2Stroke 3.0 LED Light Review and Test - Nothing Else Like It - YouTube
Couple of interesting things.
1) The LEDs now come far closer to approximating the width of the filament in a halogen bulb. The distance between emitters is 2.0 mm thick, which is ~1 mm thinner than previous best-in-class, and getting pretty close to the ~1.5 mm that filaments are in halogens.
That will go a long way to addressing the complaints about beam pattern that have been brought up in this thread on other LED bulbs. Need a test to see how much.
2) The cooling uses the air in the housing, not behind the light, to manage temperature, so you will now get the benefit of the heat from the light helping to melt snow etc. on the light in the same way as a halogen.
3) There's some interesting design around adjusting the light at install time too.
Cool engineering. Hoping to see some tests on how it does at addressing beam patter.
Yep this one will be interesting to see. The new Osram black chips allow for a very thin blade between emitter faces. I'm a little wary of them saying they will able to warm headlight housings with any significance- convection will require a lot more heat than radiant infrared light from incandescent bulbs to accomplish the same snow melting capabilities.
Yeah, I had the same thought about the warming in that it might be a 'marketing story' more than reality.
Also, I can't tell if they would actually be a solution for high beams, even if you bought one of those DLR setups that deals with the signal.
I think I saw that these will only perform DRL duty with reduced voltage input. Our trucks use PWM (pulse width modulation) so it probably won't work.
Lightwerkz ig page already did comparison test between halogen, 2stroke 3.0, 2stroke 2.0, GTR Ultra 2, and Supernova V4 on reflectors, Taco projectors and 4R projectors - the 3.0 performed best on the reflectors and taco projectors. For the 4R projectors the GTR Ultra 2 performed best follow by the SV4 then the 3.0. They concluded the performance of the 3.0 is due to the way the taco have traditional rear bulb projectors whereas the 4R are sideway projectors.
Dang, you'd think that a company who sells LED bulbs could get better testing equipment than an incandescent lux meter, measured from ten feet away.
The fact that LED bulbs perform differently depending on the housing they're in is a red flag. Halogen bulbs are held to a much higher standard of conformity.
<blockquote class="instagram-media" data-instgrm-captioned data-instgrm-permalink="https://www.instagram.com/p/CIBdcBCLLe6/?utm_source=ig_embed&utm_campaign=loading" data-instgrm-version="13" style=" background:#FFF; border:0; border-radius:3px; box-shadow:0 0 1px 0 rgba(0,0,0,0.5),0 1px 10px 0 rgba(0,0,0,0.15); margin: 1px; max-width:540px; min-width:326px; padding:0; width:99.375%; width:-webkit-calc(100% - 2px); width:calc(100% - 2px);"><div style="padding:16px;"> <a href="https://www.instagram.com/p/CIBdcBCLLe6/?utm_source=ig_embed&utm_campaign=loading" style=" background:#FFFFFF; line-height:0; padding:0 0; text-align:center; text-decoration:none; width:100%;" target="_blank"> <div style=" display: flex; flex-direction: row; align-items: center;"> <div style="background-color: #F4F4F4; border-radius: 50%; flex-grow: 0; height: 40px; margin-right: 14px; width: 40px;"></div> <div style="display: flex; flex-direction: column; flex-grow: 1; justify-content: center;"> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; margin-bottom: 6px; width: 100px;"></div> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; width: 60px;"></div></div></div><div style="padding: 19% 0;"></div> <div style="display:block; height:50px; margin:0 auto 12px; width:50px;"><svg width="50px" height="50px" viewBox="0 0 60 60" version="1.1" xmlns="https://www.w3.org/2000/svg" xmlns:xlink="https://www.w3.org/1999/xlink"><g stroke="none" stroke-width="1" fill="none" fill-rule="evenodd"><g transform="translate(-511.000000, -20.000000)" fill="#000000"><g><path d="M556.869,30.41 C554.814,30.41 553.148,32.076 553.148,34.131 C553.148,36.186 554.814,37.852 556.869,37.852 C558.924,37.852 560.59,36.186 560.59,34.131 C560.59,32.076 558.924,30.41 556.869,30.41 M541,60.657 C535.114,60.657 530.342,55.887 530.342,50 C530.342,44.114 535.114,39.342 541,39.342 C546.887,39.342 551.658,44.114 551.658,50 C551.658,55.887 546.887,60.657 541,60.657 M541,33.886 C532.1,33.886 524.886,41.1 524.886,50 C524.886,58.899 532.1,66.113 541,66.113 C549.9,66.113 557.115,58.899 557.115,50 C557.115,41.1 549.9,33.886 541,33.886 M565.378,62.101 C565.244,65.022 564.756,66.606 564.346,67.663 C563.803,69.06 563.154,70.057 562.106,71.106 C561.058,72.155 560.06,72.803 558.662,73.347 C557.607,73.757 556.021,74.244 553.102,74.378 C549.944,74.521 548.997,74.552 541,74.552 C533.003,74.552 532.056,74.521 528.898,74.378 C525.979,74.244 524.393,73.757 523.338,73.347 C521.94,72.803 520.942,72.155 519.894,71.106 C518.846,70.057 518.197,69.06 517.654,67.663 C517.244,66.606 516.755,65.022 516.623,62.101 C516.479,58.943 516.448,57.996 516.448,50 C516.448,42.003 516.479,41.056 516.623,37.899 C516.755,34.978 517.244,33.391 517.654,32.338 C518.197,30.938 518.846,29.942 519.894,28.894 C520.942,27.846 521.94,27.196 523.338,26.654 C524.393,26.244 525.979,25.756 528.898,25.623 C532.057,25.479 533.004,25.448 541,25.448 C548.997,25.448 549.943,25.479 553.102,25.623 C556.021,25.756 557.607,26.244 558.662,26.654 C560.06,27.196 561.058,27.846 562.106,28.894 C563.154,29.942 563.803,30.938 564.346,32.338 C564.756,33.391 565.244,34.978 565.378,37.899 C565.522,41.056 565.552,42.003 565.552,50 C565.552,57.996 565.522,58.943 565.378,62.101 M570.82,37.631 C570.674,34.438 570.167,32.258 569.425,30.349 C568.659,28.377 567.633,26.702 565.965,25.035 C564.297,23.368 562.623,22.342 560.652,21.575 C558.743,20.834 556.562,20.326 553.369,20.18 C550.169,20.033 549.148,20 541,20 C532.853,20 531.831,20.033 528.631,20.18 C525.438,20.326 523.257,20.834 521.349,21.575 C519.376,22.342 517.703,23.368 516.035,25.035 C514.368,26.702 513.342,28.377 512.574,30.349 C511.834,32.258 511.326,34.438 511.181,37.631 C511.035,40.831 511,41.851 511,50 C511,58.147 511.035,59.17 511.181,62.369 C511.326,65.562 511.834,67.743 512.574,69.651 C513.342,71.625 514.368,73.296 516.035,74.965 C517.703,76.634 519.376,77.658 521.349,78.425 C523.257,79.167 525.438,79.673 528.631,79.82 C531.831,79.965 532.853,80.001 541,80.001 C549.148,80.001 550.169,79.965 553.369,79.82 C556.562,79.673 558.743,79.167 560.652,78.425 C562.623,77.658 564.297,76.634 565.965,74.965 C567.633,73.296 568.659,71.625 569.425,69.651 C570.167,67.743 570.674,65.562 570.82,62.369 C570.966,59.17 571,58.147 571,50 C571,41.851 570.966,40.831 570.82,37.631"></path></g></g></g></svg></div><div style="padding-top: 8px;"> <div style=" color:#3897f0; font-family:Arial,sans-serif; font-size:14px; font-style:normal; font-weight:550; line-height:18px;"> View this post on Instagram</div></div><div style="padding: 12.5% 0;"></div> <div style="display: flex; flex-direction: row; margin-bottom: 14px; align-items: center;"><div> <div style="background-color: #F4F4F4; border-radius: 50%; height: 12.5px; width: 12.5px; transform: translateX(0px) translateY(7px);"></div> <div style="background-color: #F4F4F4; height: 12.5px; transform: rotate(-45deg) translateX(3px) translateY(1px); width: 12.5px; flex-grow: 0; margin-right: 14px; margin-left: 2px;"></div> <div style="background-color: #F4F4F4; border-radius: 50%; height: 12.5px; width: 12.5px; transform: translateX(9px) translateY(-18px);"></div></div><div style="margin-left: 8px;"> <div style=" background-color: #F4F4F4; border-radius: 50%; flex-grow: 0; height: 20px; width: 20px;"></div> <div style=" width: 0; height: 0; border-top: 2px solid transparent; border-left: 6px solid #f4f4f4; border-bottom: 2px solid transparent; transform: translateX(16px) translateY(-4px) rotate(30deg)"></div></div><div style="margin-left: auto;"> <div style=" width: 0px; border-top: 8px solid #F4F4F4; border-right: 8px solid transparent; transform: translateY(16px);"></div> <div style=" background-color: #F4F4F4; flex-grow: 0; height: 12px; width: 16px; transform: translateY(-4px);"></div> <div style=" width: 0; height: 0; border-top: 8px solid #F4F4F4; border-left: 8px solid transparent; transform: translateY(-4px) translateX(8px);"></div></div></div> <div style="display: flex; flex-direction: column; flex-grow: 1; justify-content: center; margin-bottom: 24px;"> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; margin-bottom: 6px; width: 224px;"></div> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; width: 144px;"></div></div></a><p style=" color:#c9c8cd; font-family:Arial,sans-serif; font-size:14px; line-height:17px; margin-bottom:0; margin-top:8px; overflow:hidden; padding:8px 0 7px; text-align:center; text-overflow:ellipsis; white-space:nowrap;"><a href="https://www.instagram.com/p/CIBdcBCLLe6/?utm_source=ig_embed&utm_campaign=loading" style=" color:#c9c8cd; font-family:Arial,sans-serif; font-size:14px; font-style:normal; font-weight:normal; line-height:17px; text-decoration:none;" target="_blank">A post shared by Lightwerkz Global Inc. (@lightwerkz)</a></p></div></blockquote> <script async src="//www.instagram.com/embed.js"></script>
OK, I'm going to double-down on finding someone to make a harness to fit the 2021 TRD Pro LED light setup ... the Tacoma guys have been putting those in with good results.
Major point of contention is whether or not the gentleman at LIGHTWERKZ is using the LED measuring device. I recently discovered through a man in the trade that the readings will not be accurate if using a HALOGEN model.
you could ask lightwerkz through their ig page instead of pondering here on a forum.
I did at the same time after I posted here. I'll keep you guys posted if I get a reply
Looks to be an Extech LT300. I don't think this one accurately measures the spectrum that LEDs operate in. I understand it's a comparitive measurement in this case but shifting from halogen to LED will not have a proper control subject. From what I understand they actually under-represent true output from LED. Still, a measurement of maximum intensity does not tell the whole story.
25-30 feet away...I've been to that shop many times
Better, but still not ideal. Drop-in LED bulbs can be brighter than halogen, but it's well known that their dimensional limitations contribute to lack of focus and a downward shift in hotspot placement. This is what causes nearly every hack LED bulb to have reduced distance projection.
Thirty feet at 65 miles an hour is covered in about a third of a second. This is why correct distribution and distance projection for your headlights is critical. You need your headlights to reach hundreds of feet out.
Correct.
Still awaiting on a response from Lightwerkz and Crashburn80 showed me what the different module for LED measuring is recently so I'm hoping they reply accordingly.
johnnya
