Heat issues on passenger side
super2kc
2005 4runner LTD V8
For a long time I had no heat on passenger side, freezing cold only... especially on really cold days.
I checked and had electronic dampers replaced - still no heat.
Flushed the heater core with CLR - helped a bit for a month then back to cold again.
All other possibilities were checked, coolant level, Thermostat, all electronic HVAC controls functioning correctly.
Stealership of course being the retarded pieces of @!$*&T that they are, wanted to charge me $2500 for a new heater core. as you can easily tell...I have ZERO respect for dealerships.
SOLUTION at last...
Went to Mr.Lube here in Ottawa, buddy pulled my heater core lines and blasted the heater core with with high pressure hot water into the bottom core line.
Did a rad flush for good measure.
Heat is back to like a brand new truck again.
Just thought I would share.
i also have this problem in my wifes 07 4runner. its freezing cool on pass but good and warm on the drivers side. i have a post asking if anyone has had this problem no answers. so its the heater core thats plugging up. do u thing that flushing it will last or u think it will plug up again. and how much was that to have done? im asumming u got a buddy price which i will have also once i figure out what the problem is
HI. My 2004 has no heat on the passenger side as well. It started last winter but forgot until just now. Driver's side heat is perfect. ANY further input to this problem?
Tom
seltzernator
