Height measurements, help wanted
1999 Limited. New high country shocks and 1" spacers in front and 1.5" in rear last year.
Measure from Center of wheel to the bottom of the limited fender flare.
22.5" Front
22.5" Rear, with a fill tank of gas:naughty:
Does the type of flare (limited vs SR5) change the measurement?
That's a good question I would like answer to as well.
22.5" Front
Slightly. The flare wraps around under the fender steel. (1/8"-1/4")
stock 2001 4runner
I have 175,000 miles on my stock setup.
With 3/4 tank of gas and stock size 16" wheels and tires.
Front 19.75"/33.75"
Rear 20"/34"
I'm looking for a setup that would give me around 22" but everyone tells me it doesn't exist so it was just going to buy some cheap moog 99 coils.
Front 19.75"/33.75"
Rear 20"/34"
What I used getting extra 1" on my 96 Limited bringing height to 21".
Moog
Rear - Part#MO81041
Front - Part#MO81088
"Auto Parts Warehouse" Total cost = 146.00
Price is cheap , ride is comfe and guaranteed resistance to sagging.
From there pick up some 1" spacers that will give 22" you seek
2001 Sport 4WD:
Rear 23"
Front 21.25"
I just installed a 2" spacer on the front and new 890s on the rear. I am looking at the Bilstein 5100s since I need new struts anyway. I sure hope these 890s settle down some. I will ditch the spacers once I get the 5100s and set up the 5100s for 2.5 inches. Still debating on the trim packs for the front in hopes that the 890s will settle down a little.
99 Ltd
Michelin LTX 265/70/16, not much tread left.
original springs and shocks (I presume).
1/4 tank gas
ground to bottom of fender flare:
front left, 35"
front right, 35"
rear left, 35"
rear right, 35"
Revision 6/9/14
Yokohama Geolander H/T-S, 275/70/16, @ 1/2 tread
Bilstein 4600, stock springs
removed front and rear sway bar
3/4 tank of gas:
front left, 35 1/4"
front right, 35 1/4"
rear left, 35 1/4"
rear right, 35 1/4"
My Measurements
1996 4cyl, 5spd, no a/c, no added weight up front.
@80,000 mi (125,000 km) on original gear:
20'' on all corners
now with 20,000 km on my new setup:
99 tall fronts
OME 2906 rears
Bilstien HDs
22'' on all corners
I got a 2'' lift out of the 99 tall front coils. I blame this on the lack of weight in the front of my truck, see above. The 99 tall rears left me 1'' sagging so I changed to the OMEs.
ya there are too many things that come in to play when u measure from the ground... tire size, rim size, how much tread is left, etc...
Just because it might help someone....as I am in need of hard data for this exact same thing.
96 SR5 OEM suspension 156k on 265/75/16's
Front 21"
Rear 20"
1999 SR5 (skinny black flares)
LF 22.25 ¦ RF 22.75
LR 22.50 ¦ RR 22.50
In 2000 (160,000 miles ago) I installed:
1" Lift Springs w/Bilstein Shocks
(purchased from Preformance Products)
LF 22.25 ¦ RF 22.75
LR 22.50 ¦ RR 22.50
Where did you find the 1" Lift Springs w/Bilstein Shocks ?
from a company that is now out of business "Performance Products". I believe they were bought by 4 Wheel Parts. I bought this set up back in 2000 and it was discontinued a few years later. Too bad cuz it has worked out well for me.
2002 Sport Edition
2002 Sport Edition 201,000 miles. With BFG KO2s 265/75/16, full tank of gas.
Driver side front: hub-fender: 19" Ground-Fender: 34"
Passenger side front: hub-fender: 19 1/4" Ground-Fender: 34 1/4"
Driver side rear: hub-fender: 19 1/2" Ground-Fender: 34 1/2"
Passenger side front: hub-fender: 19 1/2" Ground-Fender: 34 1/2"
Way too low need a lift stat!
Bumping this thread.
Stock:19.5/18.1
Bilstein 5100 Tacoma/T1 springs bottom perch:24.5
Bilstein Tundra/Wheeler T13: 24
Was hoping for a 1 inch rake and its actually a little lower in the rear. I think I need a front bumper to compress the front end :)
