GreyhoundGuy
Member
So I'm following the write-up by [MENTION=65614]Antman[/MENTION] and am hitting a HUGE snag. I'm hoping y'all can help. My 4R is up on ramps right now, oil drained, skid plate hanging... and I'm stuck. (There's a whole 'nother issue with the dealer that did the last oil change... but I'll save that for another post.)
I'm at this step, removing the metal filter plug (image taken from Antman's write-up):
The metal filter plug is TIGHT! I've got my ratchet set into the metal filter plug and finally got it turning, but it's not just turning the plug. It's turning the entire housing that the plug is in. In other words, it's turning the black casing that goes around the filter cartridge.
I can't for the life of me get JUST the metal filter plug out... it's 9:40pm... and I'd like to get this done tonight.
Any ideas on how to remove the filter plug WITHOUT spinning out the entire assembly? I'd like to remove the o-rings.
... or should I just put the oil in and take it to the dealer to have the part replaced? (I've done that once already... but yeah, that'll be written up in the other post.)
-Joel
-Joel
