Help me repair REAR SPOILER MOUNTING SCREW
Mindomission
Was buffing off the oxidation on the rear spoiler of my '99 T4R this morning when I noticed the right side sat a tad lower the left. Lifted up on the right side to see if it would "flex" and the bottom screw and its anchor pulled loose from the body! Go ahead, you couldn't make me feel any more like an complete idiot then I already do, breaking something that was perfectly fine to begin with. However, I still need to fix this mess. Thought of epoxying (or effective substitute), using a larger screw to thread into the hole in the body (.300" dia) or some type of Molly (the type that gets inserted into the hole and then expands on the underside of the hole as the screw is tightened). Has this happened to anyone else? If so, How did you fix it? ANY suggestions are most welcome.
Thanks, Randy
patnewton
